GE Tritonr XL GSD6260JCC Dishwasher
Problem for GE Tritonr XL GSD6260JCC Dishwasher
There is no water entering the dishwasher
By ruthzediker on Oct 28, 2009
there is no water entering the dishwasher
Solution #1
posted on Oct 29, 2009
Not Rated)
Nomodo4u
Rank: Guru
Rating: 90%, 293 votes
Check to see if you got this thing connected to a hot water pipe, turn the shut off valve to the on position, plug in your dishwasher ando make sure you got power going to it, now turn on the dishwasher.
If that don't work then turn off the hot water line, disconnect the water connection hose going into the dishwasher and get you a bucket.  Take the hose and put it into the bucket and turn on the hot water valve to flush out the sediment in the hose for a few seconds.   If no water comes out then you got a clog in the water pipe or the shut off valve is faulty.  If you got water running into the bucket, then check the back of the dishwasher pipe connection.  Look for a rubber plug that needs to be removed before connecting the dishwasher to the water line.  Also, clean the little lint filter of debris, cause sediment can clog the flow of water.
Was this helpful?
Yes
No
Solution #2
posted on Oct 28, 2009
Not Rated)
dwc472001
Rank: Wiz
Rating: 79%, 140 votes
water control valve
Was this helpful?
Yes
No
Popular Solutions for GE Tritonr XL GSD6260JCC
Questions and Unsolved Problems for GE Tritonr XL GSD6260JCC
Do you recommend GE Tritonr XL GSD6260JCC Dishwasher?
Answer
Answer
Hello. My dishwasher is not draining the water. The resevoir is full when the dishwasher is done... (More)
Answer
Dishes from my GE triton XL washer are coming out somewhat dirty and grimmy. Any suggestions?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwashers Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
