try formating in the following steps
1. right click on my computer then manage
2. click on disk management
3. right click on the flash drive then format
if the problem still occurs then there is some problem in the memory ic.
when i insert my micro sd card into my phone a warning screen saying bad format error what should i...
(More)
when i insert my micro sd card into my phone a warning screen saying bad format error what should i do?
I bought a SanDisk 4GB SDHC card for my Canon PowerShot SD870IS digital camera. It worked fine for...
(More)
I bought a SanDisk 4GB SDHC card for my Canon PowerShot SD870IS digital camera. It worked fine for about 3 weeks, then all of a sudden, it said "Memory Card Error". Although I can download the photos from the camera onto my computer (thank goodness!), I cannot delete anything from the memory card. I also tried formatting the card, either using the camera, or my computer, but neither method worked. Is there any other way to delete the photos or format the card?
im trying to add music from my computer to my phone using a 4 GB micro sd memory card using my...
(More)
im trying to add music from my computer to my phone using a 4 GB micro sd memory card using my printer
My SD card will put the My Computer Application into "not responding" status and will...
(More)
My SD card will put the My Computer Application into "not responding" status and will force me to end the procsess causing the desktop to go blank whenever i so much as open My Computer. however removing the SD card from the computer will restore the "blackout." the SD card has been used before and had several files on it when i got it as a gift from my brother. at first i thought it was the files on it already, so i got rid of them all so that there is no content on it. however the phone i was trying to use it with says there is still 7744KB still in use.
