Question about Philips Magnavox 42MF521D/37 Television
37mf321d Tv will not turn on. Will not operate with the remote. After unplugguing for 60 seconds (and plugging back in )  the tv screen will start to flash and the power button flashs but nothing happens. If I do this often enough the picture may come back. Right now I have been trying to get it back on for three days. no luck.
I had the same problem with a TV of the same model given to me .The local TV shop had said it wasn't worth fixing. I found a 2200Uf capacitor on the power supply board blown up.I replaced it and the TV works great,it was C2074,I replaced it with a 2200Uf cap at 35 volts,had a 2200Uf at 25 volts in it.I hope this is your problem also.
Posted on Jan 22, 2008
  • 106 Answers
Try to replace the Small Signal Board (SSB Assy) of your tv.
Posted on Jan 02, 2008
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
Feb 25, 2016 | Sony Televison & Video
My 39 inch tcl led TV power cord got abrubtly unplugged while watching TV. Plugged it back in and now the TCL logo on the start up screen stays there frozen. Many times already tried to unplug it, wai
Unplug the tv and hold the on/off switch on the tv (not remote) for 30 seconds. This should clear any power left in your electronic boards. Then plug it back in and try again.
Sep 14, 2014 | TCL LE39FHDF3300 39" LED TV 1920x1080, 60...
Why does my Philips 40" flat screen tv shut off 15 seconds after I turn it on?
The symptom you describe suggests power supply failure. It is still working but fading fast
Mar 24, 2013 | Philips 40pfl3706/f7 Lcd Flat Panel Tv
TV turns on in the middle of the night
  1. If the TV has a timer option, ensure it is disabled.
  2. Check the remote control to see if any of the buttons are stuck that may be interfering with the TV.
  3. Unplug the power cord of the TV from the AC wall outlet for 60 seconds.
  4. Plug the power cord back into the AC outlet.
  5. Attempt to turn on the TV.
  6. Remove all remote controls from the room where the TV is located.
OR
unplug all HDMI sources to see if a device is sending signals in the middle of the night
Oct 03, 2012 | Toymax Magnavox 37MF231D 37 in. LCD TV
My tv is not working right with picture.
Press the TV button on the remote, make sure the TV is plugged in, check the electrical outlet to make sure it is live if the TV does not turn on. If these actions do not solve the problem, press the Power button on the front of the TV. If the TV turns on, replace the batteries in the remote control and reset it by pressing the number 1 button for 60 seconds. If necessary, reprogram the remote.
Unplug the TV for two minutes, then plug it back in if the buttons on the remote don't work. Make sure the remote is in TV mode.
Change the settings on the sleep timer if the TV turns off unexpectedly. Unplug the TV and wait five minutes before plugging it back in if necessary.
Check your antenna connections and cables if the sound is okay but the picture is poor. If all the connections are good, adjust the sharpness function.
Jul 21, 2011 | RCA 20F512T 20" TV
I bought a new TV for my #2, but is says I'm not getting a signal when I hook it up to the cable. I have it on channel 60
djpeter770
You can go to TV 1 to make sure TV 2 is suppose to be set to channel 60. Did you run the auto setup on your TV? If you have already run the auto setup on your TV, unplug the receiver from the electrical outlet for 10 seconds and then plug it back in. This will make the receiver reboot and re-acquire satellite signal. Then see if you get a picture on your TV 2. If not, the last thing you can try is changing the channel from 60 to 73 through the receiver.
With your DISH remote at TV 1, press the Menu button - Main Menu will display on the TV 1. Then press 6 (System Setup), 1 (Installation), and 5 (Modulator Setup). On the Modulator Setup screen, move over to TV 2 Out and select Cable, then press select on the remote. This will automatically change the channel from 60 to 73. Highlight Done on the right and press select. Cancel out of each screen till you get back to the TV screen. Go to TV 2 and put the TV on channel 73. You should get a picture. I hope this helps.
Ray Calo
DISH Network
Feb 16, 2011 | DISH Network ViP622 DVR DTV Receiver /...
I chose the wrong channel on remote it took me to a Dish site whcih I chose to exit - when I did that my picture totally disappeared - could not get it back. It is fine on my other tvs - so I need to get...
Guest
Are you getting a snowy/blue/black screen on your TV? To get your picture back, you need to get the TV back to the correct channel or input. If the receiver is in the same room as this TV, the TV should be on channel 3/4 (normally 3) or an input setting depending on the TV. TV 2 (away from receiver) would be on channel 60/73. If you have the TV remote, put the TV on one of those channels. If you get a picture when the TV is placed on the correct channel, press and release the SAT button. This puts the remote back in SAT mode and will now operate the receiver.
If you don't have a picture, unplug the receiver for 10 seconds from the electrical outlet and plug back in. This will cause the receiver to reboot and re-acquire Satellite signal. i hope this helps.
Ray Calo
DISH Network
Jun 30, 2010 | DISH Network IR Remote Control
47" Vizio Flat screen HD LCD freezes up and remote will not work.
could it be Ch 9's digital signal is not broadcasting right? what is your refresh rate on your tv? 60 or 120hz? if its 120hz, then its more then likely the digital broadcast, if its 60hz I think its your tv can't keep up with their signal that may be at 120hz. Make since??
Jun 16, 2009 | Vizio VO47L 47 in. LCD TV
Magnavox 37mf321d/37
The only way that I know of to eliminate this problem is to buy a new TV. My ILO TV has been repaired twice since May 08 and it went out again for the third time. The problem starts out as an intermittent problem.... You turn the TV on, the audio is fine but there's no picture, you will be unable to change the channel or volume whether you're using the remote control or the buttons on the TV.
This TV should have been recalled. Don't reward the manufacturer and retailer for their bad behavior, buy your next TV from a different retailer.
Sep 26, 2008 | iLO 3200 32 in. LCD Television
This function is not available now
I think i can help you with your problem.Disconnect all cable componets from the tv everything but the tv power cord once this is done unplug the tv for 60 seconds plug the tv back in. take the tvs original remote take the bateries out once there out point the remote at the tv hold the power botton down for 30 seconds while still pointing at tv then. put bateries back into the remote and the msg should be gone.
Jun 07, 2008 | LG 42LP1D 42 in. LCD HDTV
Philips Magnavox 42MF521D/37 Television Logo
362 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
