Question about Iomega NAS P400u (32371) 40 GB Hard Drive Array
Iomega P400U I have an Iomega P400U that recently failed. Apparently during a remote firmware upgrade one of my co-works disconnected the power supply. Anyhow.. long story short we can boot the device and the hardware is functional but the OS was totally lost. I talked to Iomega and found I can get a new number one drive complete with OS however the cost is outrageous and I'd like to see about using 500gb drives to upgrade the capacity anyhow. Any idea what else I might do or use to make this system functional again. I've tried reloading it from scratch using Linux but its not that easy. I keep having problems seeing all the drives (still using 40's) etc... any help would be great!
4 Suggested Answers
  • 97 Answers
SOURCE: Hard drives freezing up
Damaged drive controller on HDD a possibility. Pull drive and test as a slave to rule out a bad RAID controller. Let me know if the drive is failing under SMART setting in system BIOS upon boot.
Posted on Jun 25, 2007
SOURCE: I have installed my iomega home media network
Check ip and mac address, see the netwok connectivity. Check DNS client and server too.
Posted on Mar 01, 2010
  • 5 Answers
SOURCE: the blue light on my Iomega StorCenter is
maybe reinstall the system drivers on your pc to access this unit?
Posted on Aug 23, 2010
How I can recover emv400 after power disconnecting during firmware upgrade
You are never allowed to disconnect power during firmware upgrade. If you do, there is no way to recover from it, except to unsolder the firmware chip and install a new properly-programmed chip.
Oct 31, 2013 | EverFocus emv400w-500, 4 ch, 500 gb,...
Tip
Upgrading your Iomega P400U
I was trying to upgrade the capacity of the NAS by adding 320 gb hard drives. I kept running into problems with the bios not supporting the drives and not finding drivers for the system. I came across an Open Source program called FreeNas that solved all the problems. It works great.
on Jul 15, 2007 | Iomega NAS P400u (32371) 40 GB Hard Drive...
Iomega screenplay firmware
you dont't update firmware. screen play dx latest firmware lot of bugs and not respond remote controller after 30min playable movie.
Aug 16, 2012 | Iomega 35039 1 TB ScreenPlay DX HD Media...
I tried to upgrade the firmware of my router(WRT54GL) but during the upgrade process I got a message upgrade interrupted but with a continue button. I pressed the continue button, but the upgrade never...
Hi just switch it off and wait for 15 second turn it should come up hope you not disconnect the LAN cable or power cable from you router during upgrade otherwise your router maybe cant be use anymore but if it is stopped by it is own it could be wrong firmware version or incompatible one you have entered should you need any help please contact me via my weblog http://computernetworksupportindubai.com/
Jul 22, 2011 | Computers & Internet
My nokia n91 is not powering on while im upgrading its firmware.
Hello Sir, This issue is seen very usually in cell phones. It is very common that after upgrading the Software's firmware, the phone's mother software fails and becomes unresponsive. This results in failure of the phone and it doesn't powers on. If a phone fails after upgrade, the company immediately voids the warrenty of the Phone. In some cases, it is impossible to repair or rollback the software. In your case, you can only do one thing. Kindly take it to a Nokia Service Center and ask them to anyhow re-install the phone's software.
Thank you Sir, Have a nice day.
Nov 17, 2009 | Nokia N91 Cellular Phone
Harmony 525 on 'safe mode' unable to work.
Just remove the bateries, press number 2 and keep it pressed until you place the batteries again! worked for me and its seems to work with other users!
tthanks!
Jul 03, 2008 | Logitech Harmony 525 LCD Remote Control
Iriver h10
This is straight out of p. 67 of the user's manaul, available on iRiver website (it may not work if the computer does not recognize the device):
Initializing H10
67
Additional information
Firmware upgrade
66
What is firmware ?
It is the operating system that works in the H10.
iriver provides you with the latest and best features through Firmware upgrade.
You can choose manual or automatic upgrade function.
For information on automatic upgrade, refer to the iriver plus instruction manual.
Manual firmware upgrade
Select [Option - Firmware Upgrade] from the menu in iriver plus.
Do not disconnect H10 during firmware upgrade.
Internet must be connected for the "Firmware Update" function.
Change to "Player must be connected to the PC for Firmware Upgrade function.
Note
Please initialize H10 player in the following cases.
All music, pictures, text, and data will be erased from the player during this initialization.
- if there appears to be corruption on the internal hard drive.
- if an error message displays and the player doesn't boot properly.
1 Connect the player and PC using the cable supplied with the player.
Open iriver plus.
Select [Option-Portable Device Initialization]. 2
Click [Start] to begin initializing.
Initializing H10
A
A
B
B
May 30, 2008 | iRiver H10 MP3 Player
System initializing
Initializing H10
67
Firmware upgrade
66
What is firmware ?
Note
Open iriver plus.
Initializing H10
Dec 18, 2007 | iRiver H10 MP3 Player
How do you update firmware on YEPP YH-J70?
unzip file, put it directly on disc don't use any program, disconnect, turn off, put on recharge and power on the player.
Dec 09, 2007 | Samsung Yepp YH-J70 Digital Media Player
My 3com officeconnect doesn't work after upgrding the firmware
Are you able to login to the router? If you can reset the router to factory defaults..If you can't login to the router...Is there an external reset button on the router you could try to reset. with a paperclip? Otherwise, I had this happen on a linksys router/switch. New router time. You should just return it where you purchased the product. There was already something seemingly going wrong if it was rebooting. 3 weeks? just return it. don't even mention the firmware update. Here is the site info for 3com: http://knowledgebase.3com.com/ OfficeConnect - Firmware upgrade fails with incorrect user interface image Problem: Incorrect user interface image Problem: Firmware upgrade fails Problem: Error when upgrading firmware Problem: Incorrect firmware Problem: Wrong firmware Fact: Firmware Fact: Download Fact: Update Fact: Upgrade Cause: The downloaded .exe has not been extracted Fix: The downloaded .exe needs to be extracted by double clicking on it. When performing the firmware update use the extracted files that were obtained from the "exe" file. e.g You will obtain a "bin" or "dlf" type of file which is the firmware required for your upgrade. Let me know what happens. Good Luck, Tim
Mar 16, 2007 | 3Com OfficeConnect Remote 612 ADSL Router
Iomega NAS P400u (32371) 40 GB Hard Drive Array Logo
69 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
