Mitsubishi WS-55809 55 in. Rear Projection Television
Problem for Mitsubishi WS-55809 55 in. Rear Projection Television
I have a mitsubishi big screen tv model 55809 , as
By gene_villare on Oct 28, 2009
i have a mitsubishi big screen tv model 55809 , as soon as i click on the television 2 seconds later it clicks off.
Comments:
Oct 29, 2009
- i tried pushing the two buttons for 5 seconds and then 10 seconds and 15 seconds and no light came on
Oct 29, 2009
- yes, i'm pretty sure its a 52 inch screen, hd 1080
Nov 12, 2009
- i open the back cardboard cover and notice the fuse was not working so i finally found the fuse and replaced itjust now. when i did the self check it only blinked 3 times,like ... . by the way ihave a little knowledge about tv cause i took electronics in high school in 1978-1980.
Best Solution
posted on Oct 28, 2009
Very Helpful)
SD Tech
Rank: Guru  Televisions & Videos  Expert
Rating: 97%, 885 votes
The model you have selected should have a self check feature: when turns off and the green power light goes off:
ON THE FRONT OF THE SET PRESS AND HOLD BOTH MENU AND INPUT together for at least 5 seconds and then release both buttons.
The power light should blink a two digit error code: for example: 2 blinks, a pause and 2 blinks--it will repeat the code about 10 times.
error codes for this set:
1, then 2 no error detected
2, then 1 X-ray protection
2, then 2 short protection
2, then 3 deflection circuit problem
2, then 4 vertical deflection problem
2, then 2 is the most common and easiest to fix.
Let me know what you find and if 2,2 I have detailed instructions for repairing that kind of trouble.
I am here to help people.
SD TECH
Comments:
Oct 29, 2009
- model number is WS55809?
Oct 29, 2009
- It does have the self check feature. Unplug the set for a few minutes and plug it back in.
Turn the set on and when the power light goes off press on the front of the TV the menu and Input buttons for 5 seconds or longer and release both.
This model has this self check--please try again. YOU HAVE TO PRESS BOTH BUTTONS ON THE FRONT OF THE TV--NOT THE REMOTE.
SD TECH
Oct 29, 2009
- BY THE WAY IF YOU DO NOT SEE A INPUT BUTTON IT IS ALSO LABELED DEVICE.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Nov 18, 2009
Not Rated)
saljoy
Rank: Apprentice  Televisions & Videos  Expert
Rating: 0%, 0 votes
I have 2 and 2 error code, what do I do now please help.
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WS-55809 55 in.
Questions and Unsolved Problems for Mitsubishi WS-55809 55 in.
Do you recommend Mitsubishi WS-55809 55 in. Rear Projection Television?
Answer
Answer
change convergence chips works great no curved lines but cant complety get all of green ghost out of... (More)
Answer
Trying to figure out to find my television code for media center Mitsuibishi Medallion CRT
Answer
when purchasing replacement convergence IC STK392-570 are they specific to the TV brand, I see... (More)
Answer
I turned on my Mitsubishi ws 55 in TV and was going to play my PS3 when I received no picture. This... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WS-55809 55 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 733
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
