Question about Whirlpool 24 in. DU920PW Built-In Dishwasher
WP dishwasher seams that the water preasure has droped and the thing that the water comes out of and spins is spinning very slow and water only comes up about 1/2 of what it use to. We have took it apart to make sure there wasnt anything blocking it or clogging it up. what do we do next? Help
  • 90 Answers
Water valve screen on dishwasher could be clogged up or you could have a bad water valve
Posted on Jan 05, 2008
Why won't my upper arm spin?
Good Afternoon Friend,
I understand that the upper arm is not spinning in your Frigidaire dishwasher, model# FDB635RF. First, check to make sure that your water pressure is between 30 and 120 PSI. If the water pressure is not good in the area your dishwasher is located, try not to use any other water in your home while using your dishwasher. Secondly, make sure that there are no tall dishes that could possibly be blocking the upper arm from spinning. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dishwasher status has changed successfully. Hope this is helpful.
-Best regards-
WP
Jun 01, 2014 | Frigidaire 24 in. FDB635RF Built-in...
Water coming in dishes not getting cleaned enough.possibly not coming out of the sprayer and spin blade
Look inside the spin blade and see if there is food or paper inside of the spin blade exit holes blocking it from spraying and spinning. Also if the spin blade is not aligned with nozzle which sprays water into the blade it will not work. I have had both happen several times. Sometimes dishes or pans pushing against the spray nozzle will also miss align the spray jet so the water does not get into the spin blade. I have also had the spin blade be completely worn and would not spin creating the same problem you've had so I had to replace it. Hope this helps.
Oct 04, 2013 | Maytag Dishwasher
Spray arms do not spray enough water for cleaning action. the holes in the arms are clear... seems like a preasure problem. The water flow sight has what looks like a black metal piece partially blocking...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 20, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Trying to troubleshoot kenmore dishwasher. water is coming in and out like it's supposed to. doesn't look like the spray arm is spinning although water comes out. help!
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 28, 2011 | Kenmore Dishwashers
I have to initate the spinning of the sprayer arm.
uasally it isnt the spinning of the spary arm that does the fill it is controlled or a timed fill then the motor comes on if there isnt enough water in the unit it will not have enough pressure really need more info though
Jun 02, 2010 | Dishwashers
Kenmore washer
Top loader? The basket at rest is slightly to the rear. Slow spin speed could be the brake hanging up or a worn clutch. If these are ok the spin tube bearings may be tightening up. Eric
Dec 04, 2009 | Microwave Ovens
Kenmore elite not washing dishes
Sounds like the motor is stuck. If your careful you can unplug the dishwasher or turn the breaker off, take the bottom panel off and reach in with your finger and spin the motor assembly.
Nov 12, 2009 | Dishwashers
Upper Arm Not Spinning on Whirlpool Quiet Partner I
Possibly, the intake screen under the lower arm is partially plugged. Take the upper arm off and inspect the holes for plugging and that the seam between upper and lower halves is not split. Our Maytag split the same seam--fixed by drilling a number of very small holes along the split and sewing it shut with fine wire.
Aug 08, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Dnby dishwasher slow...
hmmm..empty it entirely...check for any obstructions, and then, you'll need to have a service professional look into it..sounds like it's motor for arm
Mar 15, 2008 | Danby DDW496W Free-Standing Dishwasher
Whirlpool 24 in. DU920PW Built-In Dishwasher Logo
73 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
