Question about Panasonic DVD-RV26 DVD Player
HO2 error The player wouldn't play at all. The H02 error kept coming up. I took the top off and turned the white and black wheels back and forth like someone suggested. It runs now but hesitates every few seconds.
  • 82 Answers
That's the spindle motor and it has to be replaced to solve the problem.
Posted on Mar 28, 2008
How to replace the oxygen sensor
Removal & Installation Upstream HO2 S1 To Remove:
NOTE: If the engine temperature is lower than 120 °F (48 °C), the HO2 S1 sensor may be difficult to remove. Excessive force could possibly damage the threads in the exhaust manifold.
  1. If necessary remove the fuel injector cover.
  2. Disconnect the HO2 S1 sensor electrical connector.
  3. Using an oxygen sensor removal tool carefully remove the heated oxygen sensor.
To Install:
  1. Coat the threads of the oxygen sensor with anti-seize compound
  2. Install the HO2 S1 sensor. Tighten the HO2 S1 sensor to 30 ft lb (41 Nm).
  3. Connect the HO2 S1 sensor connector.
  4. If removed, install the fuel injector cover.
Downstream HO2 S2 To Remove:
NOTE: If the engine temperature is lower than 120 °F (48 °C), the H02 S2 sensor may be difficult to remove. Excessive force could possibly damage the threads in the exhaust pipe.
  1. Raise and safely support the vehicle.
  2. Disconnect the H02 S2 electrical connector.
  3. Using an oxygen sensor tool carefully remove the H02 S2.
To Install:
  1. Coat the threads of the H02 S2 with anti-seize compound.
  2. Using an oxygen sensor tool install the H02 S2. Tighten the sensor to 30 ft lb (41 Nm).
  3. Connect the H02 S2 sensor electrical connector.
  4. Lower the vehicle.
Oct 07, 2010 | 2001 Buick Regal
H02
The HO2 message means the disc is not spinning,it's not about the lens
or the laser.It is easy to take the lid off.Once you do that,plug it in,open the tray with the remote,put in a DVD,close the tray and then give the white plastic wheel on the top a gentle little nudge to get the disc spinning.
Jan 30, 2010 | Panasonic DVD-LS50 Portable DVD Player
Technics sc-dv290
i once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
Oct 26, 2008 | Technics SC-DV290 System
Error code HO2 appears after inserting dvd panosonic NV-VP30EB
To my knowledge, most H02 errors on a Panasonic DVD player would indicate a spindle error, that is the central motor that spins the disc. Normally, this would require an in-shop repair as electronics is involved, however, you could still try:
  • close the tray with no disc inside;
  • press on the back skip, pause, and play buttons simultaneously and hold for about 4 seconds;
  • when the screen blanks and then "initializing" appears, release the buttons.
Alternately, you can try:
  • remove the top cover;
  • clean the spindle motor with compressed air;
  • manually turn the spindle counter clockwise and then clockwise numerous times to exercise the motor;
  • power on the player, insert a disc and manually assist the disc to start turning.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 20, 2008 | Televison & Video
HO2 error code at screen
In line with the other Panansonic DVD players, the error seems to relate to the internal drive machanism getting stuck.
To fix you just need to carefully take the back off (disconnect power source first!), locate the drive cogs for the lens machanism and give the a couple of turns. Also a blast from a air can will help get rid of any dust build up. Pop the back cover back on and you should be working.
Looking at the other Panasonic threads on the site, this may happen on a regular basis especially as the unit gets older (and the crud builds up).
Jul 10, 2008 | Panasonic DVD-LS5 Portable DVD Player with...
HO2 Error???
The problem with your unit is the "Spindle Motor", this motor is the one that spins the disc so the laser can read it. I sugest you to take your player to a shop, or back for service if the unit still under manufacturer warranty.
Apr 14, 2008 | Panasonic DVD-RP56 DVD Player
Panasonic DVD-RP56 Error H02
I read about removing the cover and spinning the motor by hand. It was suggested without power. I found that I had to have the unit powered up when I hand-spun the motor, then everything worked perfectly... we'll see for how long.
Feb 10, 2008 | Panasonic DVD-RP56 DVD Player
Pioneer 301CD Player PD F1009 disc tray jammed
I had this same problem today on my pd-f1007
unplugged it
took off the cover screws ..2 on each side and 3 in back on top
in the middle of the unit there is a white arm with a tab on both sides
it lifts the cd into the middle to be played
the white tab had come out of the slot it was suppossed to be in on the black cd arm
just carefully ease the tab back into the slot and its like new
Jan 01, 2008 | Pioneer PD-F1009 301-Disc CD Changer
DVD not playing message say H02
There is a solution but it takes a little care because the wrong thing touched will give you a shock. Just stay away from the unit near where the power lead enters the unit. OK. remove the top of the unit, place a disk in the unit press play and gently give the DVD a gentle push in a clockwise direction. This disk should then get up to speed and start playing. It also unlocks the error. No guarantees with this one some work, some don't. I hope yours does. BMW
Jul 28, 2006 | Panasonic DVD-RV31 DVD Player
Error Message H02
I have had this problem on numerous times. Once while in warranty. Discussed with technician and he reported that the gears get dirty and stick and need cleaning. Since last year, I get this message every 3-4 months. I take out all the screws from the bottom, open the cast carefully, and use some canned air, clear all the gears, gently rotate all of them. Put everything back together and should work fine.
Dec 25, 2005 | Panasonic DVD-LX9 Portable DVD Player
Panasonic DVD-RV26 DVD Player Logo
326 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
