FixYa.com
Tags:
Acer Aspire 3100-1405 - Mobile Sempron 3500+ 1.8 GHz - 15.4
Laptop died!!! (by 2 users)
posted by bigmama66 on Jan 01, 2008
My laptop worked fine when I turned it off but now it will not come on at all. I have been told I may need a battery -do you know if all power goes through the battery even if it is plugged in? The cheapest battery I have found is 190.00 online, do you have any suggestions.
My old Acer Aspire 3500 ran on battery power until it died. Toward the end, I had to hold the power cord into the back of the computer to get a charge, and then after a while, power no longer made it to the laptop. What do you suggest?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by christaj1280, posted on Jul 06, 2008
My Acer Aspire 5002 WLMi is not getting any power. The week before it went completely dead, it seemed like there was a short in the power cord. While everything was plugged in, it would switch to the battery power. I would wiggle the cord and get it to change back to
AC power. Then one day I left it on and plugged it in, and went out for the afternoon, when I came back it was off and would not turn back on. I tried to get any of the power lights to light up, but nothing. I replaced the power cord, and when i plug it in, the light on the brick goes off. The light on the brick on the cord is illuminated when it is plugged into the wall but when I plug it into my computer the light on the brick goes off.
I thought that the battery had died and if I put a new battery in it might work. My sister has the identical computer, so when I was finally able to use her computer I put her battery in my laptop and my battery in hers. Neither her battery or her plug helped. Nothing lights up and it does not turn on. Her computer works on my battery- after her computer charged my battery. I moved my battery back to my computer and it still does nothing!
Any thoughts, help or suggestions?
Best Solution
posted on Jan 01, 2008
FixYa! (100)
softplanway
Rank:Wiz Wiz
Rating: 83%, 46 votes
heyo....if you have to litterally hold the plug at the back of the computer...you will need to have the jack wires fixed. There should be a light indicator showing that it is plugged in and recharging what you hold it....if that turns off if you let go, it is the jack....that is a flag to get it repaired.......or use a lot of duct tape. :-)
Wayne
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these PC Laptops problems?
Acer Aspire 3100-1405 - Mobile Sempron 3500+...
sound driver
i have no audio sound and i... Answer This...
Keyboard, usb and Cd don't work
Few seconds (2 minutes) after... Answer This...
Aspire 3100 - Back USB don't...
I bought this laptop almost 2... Answer This...
problem
My screen goes blue with... Answer This...
acer aspire troubles
hi, could you fix the problem?... Answer This...
Repair Service
Find PC Laptop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
