Question about Refrigerators
GE side by side Turbo Cool won't turn off
I have a model PSC23MGPA which is running constantly. I think the Turbo Cool will not shut off even if I push the button. It only stops running when I open either door.
SOURCE: Ge Side by side model PSS26MSRSS
I had the same problem with mine, but I bought the 5 year warranty from Sears. They sent me a new board (Part Number WR55X10552) and the problem stopped. This is a common problem from what the guy at Sears told me. I put the board in myself in less than 20 minutes. It's a very easy job. I saw a few of these boards brand new on Ebay for $55.00. The board is different than the one that came with the refrigerator. It's been updated, so now when you open the doors the fan motor stays on (mine always shut off when I opened the doors with the old board). Good luck!
Posted on Sep 23, 2007
  • 291 Answers
SOURCE: Refrigerator Compartment Fan
Sounds like they ran it in with your themostate and it is not working.. i would try replaceing themostate
Posted on Oct 14, 2007
  • 943 Answers
SOURCE: Hi Guys, I have a
HI thanks for your question. the problem is either that the fan in the freezer is not working, or the fridge is frosting up, or the coils at the back of the fridge are dirty. first clean the coils .it could be you problem. thanks the appliance doc please rate my answer . thanks.
Posted on Oct 09, 2008
  • 51 Answers
SOURCE: Fan not working. Turbo cool reads error
Verify you have voltage at your fan. If you have voltage and the fan is not running then it will need to be replaced.
Posted on Feb 17, 2009
  • 219 Answers
SOURCE: Freezer Fan making humming noise until Turbo Cool is pushed - GE
yes need to replace
Posted on Mar 19, 2009
My dirt devil breeze turbo shut off while I was vacuuming. I've checked 3 outlets and nothing happened
It may have overheated from a restriction or clog. If so it will come back on after it cools down.
Mar 01, 2015 | Dirt Devil Breeze Turbo Upright Vacuum
Turbo button
down of your processor there will be a cool paste i think it is gone so apply cool paste it is available in computer shops
Sep 25, 2013 | MSI Computers & Internet
Hotpoint Refrigerator constantly runs and doesn't shut off normally.
Sounds like the thermostat is not working that is what tells the compressor it is cold enough shut off.
May 17, 2012 | Hotpoint Refrigerators
My Samsung Cool' n Cool Fridge Freezer it wont stop beeping. The doors are both shut and the appliance is switched on. I have accidently broken the little plastic mechanisim that opens and closes upon...
Hello, it needs to be reset, There two reset buttons one for the frig/frez and one for the filter--drinking water/ice maker. GB...stewbison
Aug 31, 2011 | Refrigerators
My 2002 volvo s60 fan blower motor stys on after i shut ignition switch off
Your Volvo does not have have a problem at all. The feature is what is known as a 'turbo timer' and is an important part of most turbocharged vehicles such as yours.
Your volvo is powered by a 5 cyclinder 2.4 liter engine that is turbocharged. Which means the engine works on the principle of 'forced induction' whcih helps it make more power.
A turbo like yours has a small impellor placed in the early section of the exhaust which is then spun up by heated and expanding exhaust vapors. this power is then transferred back to a 'charger or pump that actually forces additional air into the engine resulting in the ability to burn a more powerful mixture of air to fuel. Unlike your engine which even under very aggressive driving will only sustain forces at most approachign 9 thousand rpm, a turbo charger often spins with speeds in the tens or even hundreds of thousands of revolutions per minute. because of this they depend on a steady stream of engine oil to both lubricate and saturate the very rapidly spinning parts to keep them cool.
when the engine is suddenly shut off after a long or spirited drive the oil pump also stops, this could result in overheating and damage to the turbo.
As a result of this, Volvo was one of the fisrt companies to install a 'turbo timer' mechanism in its T models which as you noticed will continue to operate the fan for a pre calculated amount of time after you shut the car off in order to properly cool down the turbo.
Again your car has no problem whatsoever, this is a good thing and a nice feature to have whcih will definably lend itself to extending the overall life of your engine over time.
Apr 03, 2011 | 2002 Volvo S60
My isuzu loses powerwhite smoke when engine is running oil comes out of exhaustthis is my third turbocharger in two yearswhat do you think is the problem
turbo stuffed try letting engine idle for a few mins to cool down before shutting off should last longer only use a new turbo
Jul 17, 2010 | Cars & Trucks
The dryer won't run. Dry, extra dry, and coold down process lights are lit.
Hi, the lights are signaling a control fault the is concerning the logic sector of the control board/timer. you will need to make sure that the wiring harness is connected to all points and it should be in good condition. if there are no apparent issue with the wiring harness, replace the control.
May 29, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Electric cooling fans run constantly even after vehicle is off
Try diconnecting the two wires on the temp sensor at the bottom of the radiator, you may be able to trace the wires from the fan, it that stops the fan, then replace the sensor and it should be ok
Mar 29, 2009 | 1996 Ford Taurus
Refrigerators Logo
823 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
