Question about Hunter 27185 Remote Control
Hunter Remote Control # 27185
Bought a Hunter remote controll #27185 for my daughters room. I have the same fan remote in the Master Bedroom. The DIP switches in the master are Factory default, All down. When I try to change the switches on the receverand remote in my daughters room it doesn't work. Any suggestions. Yes the remotes work on the other room lights when in the factory default .
    Problem Solver:
  • 4 Answers
Do not use the factory default position in either fan. Double check the dip switches, and make sure they are the same for each individual receiver and remote.Different codes for each. Dip switches are the oppsite direction in the remote for some reason?
Posted on Mar 31, 2009
I have a Hunter Ceiling Fan Model No. 27185. I can control the fan with the remote but can not control the lights with the remote. is there some instructions on how to operate the system?
27185 is the model # of the remote. Check to make sure your light wires are connected at the light fixture & receiver. Also, make sure your dip settings are set on the same frequency. Lastly, push the light button & pull the chain on the light.
Oct 06, 2013 | Hunter Dryers
Harbor breeze ceiling fans
There should be a setting inside the fan housing..there are usually a 3 position tab.. move one fan to a different position and corresponding remote...
Aug 29, 2017 | Hunter 27185 Remote Control
I installed a Hunter On"Off fan and light control model 27157 on a Hunter Augusta fan model 21338. I tested the remote control and the fan and light on, however, after a period of time, the fan turns on...
Most likely this is caused by radio interference from some other device nearby. Try changing the "channel" by changing the dip switches on both devices and make sure they match. :)
Mar 27, 2010 | Hunter 27185 Remote Control
I tried to change the remote codes on the fan and remote so it would stop turning on and off the fan in the other room but I can't get it to work.
When I changed the dip switches on the Hunter receiver, I noticed that the remote would not work when set to the new code. When I set it back to the previous code, it would work, leading me to determine that the receiver has some basic memory. The solution was to simply cut the power to the fan at the circuit breaker box and the new dip switch settings now work.
This was not described anywhere in the manual of the Hunter fan I purchased, so a slight oversight by the manufacturer.
Oct 12, 2009 | Hunter 27185 Remote Control
DIP Switches don't seem to matter
You need to completely power off (wall switch or breaker) when changing the dip switches. Not just power off from remote because it will keep previous setting. I learned it the hard way....
Sep 14, 2009 | Hunter 27185 Remote Control
Light goes on by itself
My solution for intermitent light on/fan off-on: It is not outside interference. It is defective receivers. I took back my second 27185 back to Menards with the exact same problem as the first. I went to Home Depot, bought a Hampton Bay model 191-691 remote unit for $8.00 less with same features and when you turn the lights off then back on, the receiver remembers the brightness level you turned off at. Been installed for a week now with no problems. Hunter would have acted up the first day.
Sep 07, 2009 | Hunter 27185 Remote Control
We have 2 Hunter ceiling fans with remotes. We can get the one in the bedroom to work great but the one in the living room now will not turn on the fan or light. Also when we are trying to get the living...
The remote might have wrong orders. Get the battery out and insert it back and see if the problem solved.
Do you set the dip switchs correctly on the fan and on the remote? Numbers set must be matched. Otherwise, the fan won't work either.
Aug 11, 2009 | Hunter 52" Ceiling Fan With Light And...
No dip switch in Hunter 27157 remote control.
Those aren't transistors in the transmitter they are jumpers. Match the jumper settings with your dip switch settings in the receiver. You can move the jumpers in the transmitter using a small needle nose pliers. An open jumper in the transmitter equals an OFF setting on the dip switch in the receiver.
Jun 24, 2009 | Hunter 27185 Remote Control
Simultaneous fans
USE A DIFFERENT DIP CODE TO THE SECOND RECEIVER AND REMOTE
Jun 01, 2008 | Hunter 21617 Palermo Brushed Nickel...
Televison & Video Logo
1,878 people viewed this question
Top Hunter Televison & Video Experts
pblo
Level 1 Expert
Paul Bade
Jim Goldsmith
Jim Goldsmith
Are you a Hunter Televison and Video Expert? Answer questions, earn points and help others
