Question about LG enV VX9900 Cellular Phone
Front screen I have an army green enV and the front screen suddenly went 1/2 normal and the other half appears smeared, color is still there it just looks like it just trails off and is unreadable.  I've pulled the battery and let it sit, but no change.  Before this it was saying it was locking but really wasn't.  So I wonder if ithis is a software issue?  Of course, I don't have insurance on the phone and I am past the 15 days return rate. Any help is greatly appreciated.
  • Faded Ninja Jan 03, 2008
    I have a similar problem. It is intermittant... Sometimes i will open up my green enV and the inside screen will be about 3/4 pixelated garble and the last 1/4 will be 2 copies of part of the original screen... as in the top half of the last 1/4 will be part of the regular screen just scaled down and the bottom half of the last 1/4 will be the exact same thing.
  • 29 Answers
As long as your phone is not showing liquid damage, Verizon will replace your phone for free.
You can either stop by a corporate verizon store with a tech department, or you can call customer service and talk to a technical representative in the warranty department. They will ship you a phone with 2day shipping. Once you receive your phone, you can activate it at the store, online, or over the phone. You keep your old battery on your new replacement phone, and mail your broken phone back in the box with the prepaid shipping label included.
The liquid damage indicator is on the back of your phone near the bottom, where the metal ports are. It should have a checked pattern on it, rather than being smudged or an entirely pinkish color.
Posted on Jan 21, 2008
Cracked Iphone 4 screen with distorted messed up colors.
Hi Connor,
Since the iphone is dropped from 4 feet, there would have been a physical damage to the display. If the phone is still under warranty or Apple care protection, you could take the iphone to Verizon store and replace the internal display. If the iphone is out of warranty, they might charge you for replacing the display for the phone. :-)
May 02, 2013 | Apple Iphone 4g Cdma 16gb Verizon
My screen has little dots appearing sometimes red sometimes blues behind the picture i just replaced the lamp bulb as i thought it would cure the problem
the projection tube needs to be adjust for color alignment, each tube (red, green, blue) must be aligned so you there would be no color smear appear on screen. if it is aligned try to set up the color balance, hue etc.
Feb 06, 2011 | Samsung Televison & Video
On left half of the screen [ KP51WS510 ], a redish shadow showing
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Sony KP-51WS500 51" Rear Projection...
Lg Env Touch on front screen keeps turning a
my best friend and mine does that too
all of them do it
all you have to do is open it and close it back and it goes away it doesnt hurt the phone at all
Feb 28, 2010 | LG enV Touch VX11000 Cell Phone
Will not focus
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Feb 02, 2010 | Hitachi 57F500 57" Rear Projection...
Horizontal color line across the screen
Most likely a bad Vertical IC or bad connections on the vertical IC. don't continue trying it on. If you have a bad connection it could do more damage. You also could damage the CRT ( picture tube ). If you remove the cover and look at the bottom side of the PC bord with a good magnifiing glass you may see what looks like rings around the leads comming from the Vertical IC. The Vertical IC is mounted on a heat sink usually towards the front of the set looking from back. If you do see the rings around the leads try reheating with a solder iron. If this dosen't fix you most likely need a new IC.
Apr 15, 2009 | Televison & Video
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
Color distortion for Sony KPR-46cx35
there maybe cold solder around the chroma section, or in the CRT board....
Aug 11, 2008 | Televison & Video
Main display went black on enV
Yeah same with mine... the front screen went black.... it started to get lines up and down... then all of a sudden just the front screen turned off! :-(
Jun 02, 2008 | LG enV VX9900 Cellular Phone
Bad picture
Try to consider the following tips:
Smearing out of one or several colors, best seen in txt-mode, my 27CE4599/30R smeared out in red and green, not in blue, fully exchanging the drivers (input and output complete, otherwise the RGB driver will blank the crt) moved the fault to the other color
Replace the 180K feedback resistors in the amplifiers with normal 1/4W metal film instead of 1/8W, they can become open circuited (in mine both green and red were faulty in this way). Change all 3 and not just the defective ones, replace also all the paralleled 75K resistors per color (fe by 47K+27K) to prevent bright color raster (they can also become open circuit)
Nov 29, 2007 | Toshiba 55H70 55" Rear Projection...
LG enV VX9900 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
