Philips tv powering it's self off
I have a philips big scren tv, it turns it's self off, sometimes it takes hours, and sometimes it takes min. I have tryed everything, please help me.
model # 43P8341
serial # 67102129
  • krispy6801 Jan 02, 2008
    I have a philips rear projection tv that powers it's self off, model # 43P8341. It takes up to a few min. or a few hours.
    Guru:
  • 1,894 Answers
Most of these complaints are the SSB board problems. else other possiblity is to reseat low signal card.
even after that problem is not solved means the product ias of low quality. just go and replace the defective product.
Posted on Jan 02, 2008
  • 3 more comments
  • dewan nafees ahmed Jan 02, 2008
    krispy, if you have no TV rePair experience, please play it safe and call out a
    tech to assist you in this repair. A TV set is not a place to be
    experiementing around with,
    Your problem could be the power supply or the light circuit could have
    a fault. Does the sound go away at the same time? Yes I would quess
    the power supply or the main board is bad. No? The bulb circuit most
    likely is defective. These TV sets have no user replaceable parts
    inside of them and should be diagnoised and repaired by a trained
    technician. Good Luck, and let us know what was done to repair your TV.
    i got this from another forum. check out this reply too.
    Some times the problem is the front control board. There is a bad
    connection on it, one or more of the tact switches are bad, or the
    remote sensor is defective. Some time Its nothing more then a cold
    solder connection in the sweep section of the Hi Voltage circuit, or
    theres a small coil right off the horizontal drive transformer,
    secondary side, thats also connected to the Base of the horizontal
    output transistor, that needs to be taken out, the enamel on the leads
    need to be scrapped off and reinserted and resoldered. Depending on the
    model and how old the set is. Also theres several standup coils in the
    horiontal sweep and corrections circuit that have poor solder
    connections on them. And last but not least The power supply could have
    bad connections or have an intermittant regulator componet. My bet
    would be the small horizontal drive coil. The problem with the set
    changing channels could be the remote controller. try taking out the
    batteries first,if that dosent work then theres most likly a defective
    infared sensor for the remote inside the set or the B+ that supplys the
    voltage to the sensor is noisy such as a bad capacitor off that feed
    supply. Now one thing to remember is safety with these sets. maybe,
    before going inside a set, you should read this http://www.techlore.com/article/14476/ or http://www.techlore.com/article/10602/ Good Luck
    problem caused by a defective or poor fitting front panel button assembly. re[lacing it will make TV work.
  • dewan nafees ahmed Jan 09, 2008
    problem caused by a defective or poor fitting front panel button assembly. replacing it will make TV work.
  • 373 Answers
You have a bad SSB module inside the set. It plugs in and could be easily removed by anyone with a little common sense. It is located (looking from the back into the chassis) on the left side and sticks up vertically and is about 5or6 inches by 3 inches and has a white wire ribbon plugged into it. The part number is PH3912725871 and costs about $99.00 plus shipping exchange at a parts distributor After installing you may have to reset the picture by going into the service menu on the remote press 0-6-2-5-9-6 then MENU
Posted on Jan 01, 2008
  • TV Doctor
    TV Doctor Jan 02, 2008
    You must consider how good the picture is while it is playing before investing money. If you try to fix yourself please do unplug the power as you should well know.
  • TV Doctor
    The most likely problem is the SSB board because I have fixed the problem before with it. If I was going on a service call on this model I would be taking an SSB board with me!
    Sergeant:
    Champion:
  • 347 Answers
Hi krispy,
Most of the times that happend is due to a bad power source.
Try unpluging it for some minutes, and plug it again.
If the problem continues check that the socket isnt shared by many devices. Connect the TV direclty to the socket and unplug any other devices.
  • Santiago Vallejo
    Santiago Vallejo Jan 02, 2008
    Hi again Krispy,
    If you are sure its not a power problem, Then its an internal lose of high voltage
    Then it can be either the SSB (small signal board), the flyback transformer, or the horizontal output driver. (both the flyback and the horizontal output)
    That is very hard to repair, even if you ar a bit rxperienced in opening TVs, i recomend you to get prefecional assistance.
MY philips 42 inch plasma TV model 42pf3320/10 screen goes black after a few mins sometimes. what can i do to fix it???
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 01, 2012 | Philips Televison & Video
Where can we get an on/off switch for philips flat scren tv model 32PF3320
The power button for the "Philips widescreen flat TV 32PF3320" if located, if you are facing the screen, on the Left-Hand Side Edge of the television.
Feb 28, 2011 | Philips Televison & Video
My mitsubishi 60 in turns off by its self some times 5 min after you turn it on sometimes 5 hours and sometimes 5 days. you can tell when its about to turn off by line that flash on the screen. then they...
Well if your tv is older like the one in the pic it sounds like the bulb is overheating, you may want to vacuum the dust out of the back and make sure it isn't got block of air flow in the back and also make sure it isn't up against a heat source
Feb 19, 2018 | Mitsubishi VS-60607 TV
Tungsten E2 has lit screen & not responding
You can take the back off and unplug the battery for a few mins, this sometimes will clear a logic lock
Feb 27, 2009 | Palm Tungsten E2 Handheld
I need help tv plasma phillips
There is a firmware that can be updated via usb from philips. This fw was used to correct the tv powering on with no picture randomly (they called it a maintence session) but it was a problem. The tv would power on on its own and do this..
If that doesnt take care of your problem then the problem is with the main control board. or ssb
Aug 01, 2008 | Philips 42PF9630A 42 in. Plasma Television
Red light blinking
My one take too long to turn on, relay/green light on and off for hours before it can start, I use a hair dryer to heat it up everytime, aim at the center from top, then it turn on very faster, no need to service
Feb 28, 2008 | Philips 32FD9954 32 in. HD-Ready Plasma...
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
