Question about Kenmore 24032\24036 Top Load Washer
Kenmore Clothes Washer leakes when filling,it's a top loader.
My kenmore washing machine is leaking when it is filling.The washer is 1yr old,can you help me?
  • 1 more comment
  • SPYGLASS94 Jan 02, 2008
    -the washer is leaking from the bottom, again only when it's filling.
    thankyou for trying to help.
  • Anonymous May 03, 2009
    Kenmore washer leaks while filling
  • Anonymous Mar 26, 2014
    leaing while filling
I had a similiar problem with my washer back in Sept. I discovered it was actaully leaking from under the washer, IAt first it appeared as though it was running down from the top of the washer somewhere. I pulled the washer out and had my son hold it at an angle to see if I could determine where exactly it was leaking from.That's when I discovered it was actually cominig from the Plastic Pump located directly under the tub. In the center part of the pump, there is a circle, surrounded by grey sealant, (on mine), straight from the manufacturer and within a year and a half, the sealant developed a hole which caused mine to eventually pour water from it while filling. It was very simple to fix and only $50.00 for a new pump. Sure Beat those hard to swallow service fees. Good Luck!
Posted on Jan 11, 2008
  • 196 Answers
When you say it is leaking when it is filling, where is it leaking ? Inside or outside the machine ?
I'lll try to help once I know the answer to the above
Posted on Jan 02, 2008
  • Elmer Vest
    Elmer Vest Jan 10, 2008
    If it leaks only when filling then I sugest checking the water inlet flume at the back of the machine. (The flume is where the water enters the tub) Sometimes the flume will get bounced around and has to be re-aligned if it hasn't broken.
well I found out the problem was the pump itself, it had stared to leak, but the other solution could also have been the culprit.
Thanks for you help.
Spyglass94, this was the problem for a top loading Kenmore, leaking water out of the bottom while it was filling with water.
My Kenmore 700 series washer has been leaking water. When the tub is filling with water, water seems to leak along the front bottom edge of the machine in several areas. I'm left with a huge puddle of...
First ck to see if your water pump is leaking. It normally leaks when the machine is running not just filling. Also look at all the attaching rubber hoses under the machine and see if water is leaking down the back right side of the machine and then running around the frame to the front long shot but possible.
Aug 11, 2010 | Kenmore 15864/15862 Top Load Washer
Leak in machine
You need to turn the taps off when not in use. Some machines actually stipulate this in their manual. My new machine certainly did (yet it was never an issue with my old machine)
Jun 12, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore Washer leaks
When my husband came home he took the washer apart and it was the pump. Small pin hole leak in this glob of gray sealer that seals the two plastic parts together. Just been waiting to fail, I'm sure. Thanks for your help.
May 28, 2009 | Kenmore Elite 45986 Front Load Washer
Water leak
May 14, 2009 | Kenmore Washing Machines
Kenmore front loading washer leaks
under the front panel ther should be techshet/ trouble shooting guide. and withthe front panelremoved perhaps you can see ewhere the leak is coming from
Mar 01, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE4T Washer Leak
there are 2 possible causes.
inlet valve leaking - turn water off and if water fill stops, it indicates valve leaking
valve being powered when machine off. this is very unlikely but to check, disconnect washer and see if problem stops
also, if drain is plumbed into a spigot on the sink trap, every time you empty the sink, some of the water will flow into the machine. to cure this, take the drain hose as high as possible under the sink in a swan neck
Oct 20, 2008 | Kenmore Elite 45986 Front Load Washer
Washer leaks after installing new lid switch
Glad this was taken care of. I'm just closing out some old tickets here.
May 18, 2008 | Kenmore 24032\24036 Top Load Washer
i have the same onebut fridgeair but mine would only wash and nothing else and it turned out to be the motor was weak
Apr 14, 2008 | Kenmore 44042 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
206 people viewed this question
Sal De
 Brian Main
Brian Main
