GE D52GW12 52 in. Rear Projection HDTV-Ready Television
Problem for GE D52GW12 52 in. Rear Projection HDTV-Ready Television
TV doesn't turn on
By castworks on Oct 28, 2009
TV doesn't turn. Before the TV no longer was able to turn on, when pushing the I/O switch, the on light would stay lit for about 2-3 seconds and then shut off. Had to continuously push the on button to get the TV to start. After awhile, this no longer works.
Best Solution
posted on Oct 28, 2009
Very Helpful)
rusty_etech
Rank: Guru  GE Televisions & Videos  Expert
Rating: 91%, 139 votes
Most likely you have some bad capacitors on the power supply PCB. These sets are famous for this problem. If you try to tackle it yourself, look towards the front of the supply and you will see these capacitors bulged on top. There are normally about 4 of these that I change. The board will have to be pulled out so that the solder joints can be accessed. Thanks
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for GE D52GW12 52 in. Rear
Questions and Unsolved Problems for GE D52GW12 52 in. Rear
Do you recommend GE D52GW12 52 in. Rear Projection HDTV-Ready Television?
Answer
Answer
Magnavox model Fp5230 W104 Chassis PTV620-AJ01 Power light comes on and stays on, can hear tv kick... (More)
Answer
When turned on the green ligth goes on, the button lights but it goes of in a few second, then by... (More)
Answer
the picture on my d52dw12 is bowed in significantly on the sides and slightly on the top and bottom.... (More)
Answer
my Mom has a GE model D52GW12 TV picture has been fine. turned it back on today and figures are off... (More)
Answer
The power light comes on but fails to connect. What is the problem?
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in Newport, KY
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
