Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Need help I just connected the router to my main laptop but I cant get connection with my desktop
  • 556 Answers
Is your laptop working completely -- including to the internet to access web pages with its current router attachment?
Is the laptop connected wirelessly or by a wire?
Is the desktop connected with a wire or wirelessly?
Was the desktop connected to another device before?
Was the desktop configured to login before especially if it was not connected to the router before?
Did you configure the router to do the login that used to be done by the desktop before, if that was the case?
If the router is now doing the login did you configure the desktop not to login if it is no longer needed?
Did you configure IP addresses, subnet masks, gateway addresses or DNS addresses into the router before?
Does having the router mean these should be removed and the desktop switched to accept dymanic addressing from the router?
These are quite a few questions and you may not be able to answer them all. Answer what you can in a comment to this issue and I will attempt to determine a plan to get your desktop connected.
Posted on Jan 03, 2008
6ya staff
SOURCE:
Set up my netgear router. laptops show that they are wirelessly connected to the main computer, but we cant get them to connect to the internet. also lost the netgear cd that came with router. do we need...
The netgear router installation will set up the internet connection during install.
Download the Router driver from netgears website and install on the computer/s then your up and running.
it appears you wireless card is seeing the router so just install the drivers and your set.
Oct 03, 2010 | Computers & Internet
Laptop cant connect to internet
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Apr 06, 2010 | Linksys Wireless-G Broadband Router
Cant connect old comp to new router
go to > control panel >network connections > in left hand pane.under Network Tasks..click..Create A New Connection... that will start a wizard and will guide you thru the process. you will also need to install the drivers as well for his computer to be able to use the modem/router.
i hope this has helped
Sep 09, 2009 | HP Pavilion a330n (Refurbished)...
Belkin router
I'm guessing that your laptops are using a wireless connection. If this is the case the first time you enter the wireless security key (password) it will be stored in the laptop so you don't need to enter it again.
To connect to the router, you need to open its associated web page which you will normally find by typing the routers IP address into the address bar in Internet Explorer. The usual default address for a Belkin router is 192.168.2.1.
Once you connect to the router you should be able to access all the security settings from the Belkins main menu.
Sep 11, 2008 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Connection to my Desktop not working.
Try and change the cable from the router to computer with a new one and do the same with the modem and see if connects. Hopefully it's just the cables that are faulty.
Aug 11, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Cant connect to wireless router
Make sure the wireless adapter is enabled on the elonex laptop and its properly installed.
Connect wirelessly on the elonex one laptop using the same SSID and security key that you used on your main laptop.
Aug 07, 2008 | Belkin (F5D7230-4) Router (587009)
Need help with connect a d-link,dl 624 router
You wireless router/access point can host several simultaneous connections to the internet. Just connect your laptop to the wireless network as you would from your desktop computer.
Hope this helped.
MO
Jul 11, 2008 | D-Link AirPlus Xtreme G DI-624S Wireless...
Cant connect from laptop yet can off the desktop???
umm i dont abought this scenario but i think you need a belkin 2 usb connectors one for yur desktop and one for your lab and then try to connect them if u have a wep key u have to put it in it is a password to get on the internet, another thing you can do is fill in the i.p adress specifically , and if all that doesnt work jus connect a 6 foot wire to the desktop or lab it will get you on the internet
Jul 01, 2008 | Belkin (F5D7230-4) Router (587009)
Pc connection problems
Sounds like you are setup to use Internet Connection Sharing. don't do this. Have each computer connect to the internet via the router. If the router is wireless connect all computers wirelessly to the router that are wireless capable and any computers that are not wireless capable, connect them to the router via a cat5 cable to the cat5 ports on the router. This will solve your problem. BPCS
Dec 30, 2007 | Belkin (F5D5231-4) Router
Setup Question
no if your pc is connected to the router, then that one has its connection which i assume will be either usb connected or ethernet connected. You laptop will connect via the wireless connection to the router, not your pc, so as long as your laptop has a wireless adapter then it will independantly connect to the router, your other pc does not have to be switched on as your router is connected to the net as long as it is switched on.
May 28, 2007 | D-Link DI 514 Wireless Router (DI-514)
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
60 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
