Maytag Atlantis MDE7400AY Electric Dryer
Problem for Maytag Atlantis MDE7400AY Electric Dryer
Dryer not heating
By davo_richard on Oct 28, 2009
dryer not heating
Solution #1
posted on Oct 28, 2009
Not Rated)
hunter19_46m
Rank: Guru  Maytag Washers & Dryers  Expert
Rating: 91%, 269 votes
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be with the heating coil.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Was this helpful?
Yes
No
Popular Solutions for Maytag Atlantis MDE7400AY
Questions and Unsolved Problems for Maytag Atlantis MDE7400AY
Do you recommend Maytag Atlantis MDE7400AY Electric Dryer?
Answer
Answer
I have a Maytag Atlantis dryer MDE7460AYW. I ordered the replacement timer which is supposed to be... (More)
Answer
how do you get the top of a maytag alantis electric dryer off
Answer
I have a brand new dishwasher. it doesn't seem to dry as fully as my old one and there is... (More)
Answer
Everything appears to work except no heat is being produced by the dryer.
Answer
maytag neptune gas takes have to run two cycles to dry clothes
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryers Experts
Top Washer & Dryer Repairmen
in , CA
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
