Vacuums Logo
Posted on Oct 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dyson Makes a loud noise like something is impeding the
Makes a loud noise like something is impeding the belt when carpet is selected and vacuum is being used. No noise when upright. Belt is intact. Roller will spin with assitance
Anonymous
Level 3:
  • Master 701 Answers
  • Posted on Oct 28, 2009
Anonymous
Master
Level 3:
Answers
701
Questions
0
Helped
298471
Points
1875
I would try changing the belt. Even though the belt may look fine it can be stretched or worn and that can cause loud noises. You can get dyson belts here:
http://www.vacbelts.com/dyson.htm
Dai Boyce
Level 2:
Sergeant:
  • Expert 288 Answers
  • Posted on Sep 21, 2014
Dai Boyce
Expert
Level 2:
Sergeant:
Answers
288
Questions
Helped
158105
Points
858
Sounds as if the roller bearing may be of center and is squealing. The belts do sometimes go adrift if may need to be realigned, If it is not the belt . Contact Dyson regarding the fault.
There is a 5 year warranty on parts their customer service is amazing . They may send you a part to fit if faulty .
1helpful
Why does my dyson now make awlful noise on the carpet setting
It might be the clutch. Mine did it because there was dirt stock in the end caps if the roller. Instead of the belt breaking a clutch kicks in and makes a loud flapping noise.
Dyson dc17 makes loud noise on carpet setting. It's like a high pitch ringing almost but won't make the noise on hard floor, only carpet setting. Ive checked for blockages and cleaned all parts but makes...
It is probably the brush roll motor making the noise. Remove the brush roll & belt and turn both motors on. If you do not hear the noise when both motors are running the noise is likely coming from the brush roll
1helpful
Older Dyson 07 Animal, loud ratcheting noise on carpet setting
That is an indication that the belts are worn, stretched or broken. You simply need to replace the belt. Here is a link to the belt(s) you need and a manual you can view:
Dyson DC07 Belts and Manual
When I tilt back handel and turn dial to carpet It makes a loud grinding noise
On a Dyson this engages the brush bar. Two possible faults: Debris (hair etc) caught in brush bar - cut out with knife. Or - damaged drive belt - pieces of belt striking casing. Last, but unlikely cause, debris in bearings of brush bar - replace brush bar.
Belt wont turn makes a loud noise when put on carpet setting
If this is a Dyson with a protected belt that can't be replaced then it will have to be sent out to Dyson or get a Dyson servicepersonnel to check it over - protected belt motors are difficult to fix by yourself. If its clicking all the time, then it means the belt has to be replaced. In the mean time check that there are no obstructions on the beater bar and behind it and also check that the brush stop roller at the top of the hood is in the right position. It should move automatically when the handle is swung down in normal operation.
2answers
Suden loud noise when vacuming carpet
Hi.
Check that brush roller (beater bar) is free to turn with no obstruction.
If it is still noisey after doing this try this site for Dyson repair manuals.
http://dysonmanuals.inc.io/
Chris.
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
