Broan-NuTone CV450 Central Bagged Central System Vacuum
Problem for Broan-NuTone CV450 Central Bagged Central System Vacuum
The wall outlets do not turn on. The motor runs at
By jane765 on Oct 28, 2009
The wall outlets do not turn on. The motor runs at the unit. I have reset and it blows/sucks at the unit. The canister is empty.
Thanks, Je
Solution #1
posted on Oct 28, 2009
Not Rated)
Chemist1961
Rank: Guru  Vacuums  Expert
Rating: 93%, 136 votes
You main low voltage line from the vac to the house is likely disconnected. Start by looking at the connection where the small wires enter the vac. Touch across those two wire terminals with a screwdriver or needle nose pliers and the vac should start.If it does, inside the home those same wires run along your pie to each inlet. Somewhere along the pipe path the wires have been disconnected or broken.. Think back to any area where work has been performed or face plates removed for painting, etc. Remove each inlet one at a time and look for a loose connection on the screw terminal at the back of the inlets. When reinstalling be certain each wire is tidy and connected to only one screw terminal at the back of the inlet. Once all inlets are connected in line you will have a complete circuit back to the vac. Post back with results
Comments:
Oct 28, 2009
- You main low voltage line from the vac to the house is likely disconnected. Start by looking at the connection where the small wires enter the vac. Touch across those two wire terminals with a screwdriver or needle nose pliers and the vac should start.If it does, inside the home those same wires run along your pie to each inlet. Somewhere along the pipe path the wires have been disconnected or broken.. Think back to any area where work has been performed or face plates removed for painting, etc. Remove each inlet one at a time and look for a loose connection on the screw terminal at the back of the inlets. When reinstalling be certain each wire is tidy and connected to only one screw terminal at the back of the inlet. Once all inlets are connected in line you will have a complete circuit back to the vac. Post back with results
Was this helpful?
Yes
No
Popular Solutions for Broan-NuTone CV450 Central
Questions and Unsolved Problems for Broan-NuTone CV450 Central
Do you recommend Broan-NuTone CV450 Central Bagged Central System Vacuum?
Answer
Answer
CV 450 bags bust: I have a Nutone CV 450 - already had one motor replaced because the bags keep... (More)
Answer
Have a Nutone 450 - started vibrating and smoking - believe it may be a bearing in one of the... (More)
Answer
Unit keeps running after manual override switch in OFF Low voltage wires disconnected>... (More)
Answer
The system is only a few years old. It will not power up even from the switch on the base unit.... (More)
Answer
Nutone CV450 attachment. Broken geared belt. Unable to find
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuums Experts
Top Vacuum Repair
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
