Question about Lindhaus Activa 30-38 Bagged Upright Vacuum
Lindhaus Activa 30 EOS Version
When I turn on my machine, it runs for a few seconds and then turns off. The red light indicator for the electronic overload control turns on. I took the brush out and made sure there were no obstructions. What else can I do?
  • Anonymous Jan 27, 2008
    I HAVE THE SAME PROBLEM MY LINDHAUS ONLY RUNS FOR A FEW SECONDS AND THE RED LIGHT COMES ON I HAVE GONE THREW AND CLEANED THE ENTIRE VACUUM INSIDE AND OUT LITERALLY MUST HAVE MY LINDHAUS FIXED PLEASE
  • smirl Jan 10, 2009
    I have the same problem. After dissasembly, I observed the motor running prior to it's auto shut off. The armature and brushes looked like the 4th of July with all the sparks shooting out. I'm sure it is either the board or motor. I Hoped this vacuum would last more than 50 hrs.
    President:
  • 1,673 Answers
Check the inlet by the brush roll for a clog, also check your hose for a clog. Usually when there is a clog, it is sensing an overfull bag and will shut down to protect the motor. If there are no clogs, then there could be a problem with the circuit board or motor.
Posted on Feb 14, 2008
6ya staff
SOURCE:
Why does lindhause Activa 30 hose on vacuum comes off
My hose comes off as well. It gets 'unscrewed' over time using it. Simply screw it back in counterclockwise...
Sep 01, 2014 | Lindhaus Activa 30-38 Bagged Upright...
The suction comes on but the motor doesnt turn the beater bar nor does the red or green light come on
check to make sure power is coming from wall with a voltage meter, if not wiring issue or blown motor or wiring around beater motor
Feb 28, 2014 | Lindhaus Vacuums
No suction in hose
Remove the machine side of the hose--is there suction at the machine? If so, run a broom handle or similar through the hose to dislodge the clog. If no suction at the machine, you may need to fish out debris with a hooked stiff wire from the port. Remove the bag and examine the port area underneath for similar clogging. Finally, check the brush area underneath the machine bottom plate for more obstruction. Also, check the brush assembly for debris accumulation. Remove the drive belt and check for free turning of the brush. If turns hard, remove the brush, clean the bearings and roller pins, then apply a small quantity of light oil like 3-1 or sewing machine oil. Hope this helps!
Jun 20, 2010 | Lindhaus 380 Diamante Bagged Upright...
Sucton motor doesn't come on
If the debris cleared itself, it may have gotten into the vacuum fan assembly and jammed the motor preventing turning. Also, check the vacuum motor brushes and springs for damage. Hope this helps.
Dec 05, 2009 | Lindhaus HEPA 14 HealthCare Pro Bagged...
Getting the vacuum to start after replacing the bag
Behind the door and above where the bag is located there should be a piece of plastic, or metal that sticks out, at least in the manual, if the door isn't shut correctly, that piece doesn't push in the switch that is behind there, this is a safety feature built into a lot of vacuums, to keep people from running the vacuum without a bag in it. Most likely your lid just didn't shut completely. Check for that, and get back to me.
Jan 20, 2009 | Lindhaus Activa 30-38 Bagged Upright...
Model EL7020 will not stay running!
Try turning the knob on top of the machine all the way to the right and try it again
Dec 04, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Convertable?
It is a vacuum, you would have to consult where you purchased it, they should know what you add to it.
Mar 16, 2008 | Lindhaus Activa 30-38 Bagged Upright...
Red light stays on
Most likely the hose or the inlet down by the brush roll has a clog in it. The red light indicates a full bag, but if there is a clog, then it thinks it has a full bag.
Dec 07, 2007 | Lindhaus Activa 30-38 Bagged Upright...
Lindhaus Activa 30-38 Bagged Upright Vacuum Logo
583 people viewed this question
Top Lindhaus Vacuums Experts
vince
Dennis Webber
Are you a Lindhaus Vacuum Expert? Answer questions, earn points and help others
