Question about Epson Stylus Photo® R800 InkJet Printer
Epson R800 prints very wet, very very smeared pictures
What could be happening? Any help would be much appreciated!
  • Vividjen Jan 03, 2008
    I am using the same glossy paper as before and using the same settings. It is as if the gloss is dumping all over the page.
  • Epson Master
  • 1,879 Answers
It depends on the type of paper you are using. it is how the ink chemicals react to the chemicals on the photo paper.
Posted on Jan 03, 2008
How can I clean the ink pad?
Take a look here, these issues with the ink pads/cartridges can be a true pain but give this a try:
http://www.wasteink.co.uk/adjprog-tutorial-ver2/
EJ Kudelka
Mar 13, 2012 | Epson Stylus Photo R800 InkJet Printer
I suspect this will be a tricky one! I am printing from a new iMac / CS5 setup. I am using OCP inks and Ilford paper. I am printing the same images to both machines. The print settings are identical....
hi Anthony, i spent a month trying to figure out a similar problem with an epson 2200. Now, the printers are different but not that much, and, the changes in paper and ink gave me "some" color issues but not as bad as what i was getting. your problem seems very similar. i run a PC so this is similar but not exactly the same. what i found was that a Magenta/ violet cast was due to double profiling. I could verify that i had the correct settings but i was wrong! I print from CS3 into the epson 2200. What i found was there is an error(no one is talking about) in the printer driver. You cannot shut off the color management completely! Assume this scenario, you are printing with CS3 applying your profile in CS3. Make the settings in CS3 as normal, then you are directed to the printer settings. Go to the print driver and make the selections for ICM Color, and select "no color". The KEY is to make sure you do this step LAST , make sure to click on the "apply" button, then "Close". Once you make the selection of "No Color" do NOT click on anything else. If you change screens in the print driver once you select "no color mgmt" the driver CHANGES your settings. ANY settings in the other pages in the print driver cause the driver to apply a printer profile, this effectively "double profiles" your photo print causing the magenta cast. None of this should happen if the driver was created correctly but there it is! It took a long time to test and verify but it is as i stated. Once i got it sorted out my photos are excellent ALL the time. Good luck, worm1855.
Nov 21, 2010 | Epson R800 InkJet Printer
Is there a maximum file size the r800 will print.
r click on printer go to preferences select second tab PAGE SETUP go to bottom and see OPTIONS and see if the printer data size spooler is ticked
this controls the amount of data sucked up into memory in any run. so printer will pause to take the next bytes of data to print.Instead of all the data in one hit
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Epson Stylus Photo R800 InkJet Printer
Epson Stylus C86 smearing
Your printer has ink build up inside it. This comes from cleaning cartridges and builds-up steadily over time. Remove top cover. Wet a cotton swab with isopropyl alcohol (available at drug stores) and clean the inside. use a cotton bud where the swab gets entangled.
Aug 07, 2009 | Epson Stylus Photo 1290 InkJet Printer
Epson Stylus R220 CD Print Smears after printing.
It has to be a bad batch or the wrong system.
Are you sure that the disks are labeled inkjet printable and not lightscribe?
Most printables are white in color and lightscribes are tannish.
Jun 18, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson RX595 prints "wet" on non epson paper
the reaction of the photo chemicals that are on the paper cannot be guaranteed by the printer manufacturer as they have no knowledge of its composition.
3rd party photo paper manufacturers have better compatibility results.
epson for epson, kodak for kodak, hp for hp
Apr 09, 2009 | Epson RX595 Photo All-In-One Printer
Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
Aug 25, 2008 | Epson Stylus Photo R800 InkJet Printer
Help! Prints a smeary mess!
it depends on the type of paper you are using.
manufacturers have ¨recommended papers¨ : )
recommendation: ask for paper samples from paper vendors
Jan 01, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson R1800 and Imac intel
Not sure about this as Mac's are not my bag. Try removing the driver and software you installed. reboot your PC and make sure the printer has gone from the list. Reistall the latest driver you downloaded from Epson and try it again.
Apr 24, 2007 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo® R800 InkJet Printer Logo
129 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
