Pioneer SD-532HD5 53" Rear Projection Television Logo
Posted on Oct 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a model number sd-p503p-k i dont know how to add channels after channel 65?
Anonymous
Level 2:
Scholar:
  • Expert 87 Answers
  • Posted on Oct 28, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
87
Questions
0
Helped
29523
Points
257
You probibally need to re-scan your available channels. The TV goes through and grabs all of the available channels that it sees so you don't get any all static channels while your surfing the tube. The manual is actually about 35 megs so I cannot post it here, but here's what it says; - Hit Menu
- Select Setup
- Select Channel Setup
- Select Auto Channel Preset
- Select Antenna and change it to A or B, whichever one your using.
This should fix your problems, unless your area doesn't have channels past 65. If that's true then everything I just wrote is irrelevant, but there ya go!
I want to save the channels and turn my antenna to another direction and scan I loose the channels that I had can I save them some how?
The only way that I solve this issue is to write down the channels available from one direction on paper. Do the scan in the second direction. Return the antenna to the first direction and then manually add the rest of the channels. Depending on the TV, you either type in the channel number with the remote control or find a Add Channel option in the TV Channel sub-menu.
At least with my TV that doesn't have an Add Channel option in the Channel section, going to a digital channel with the remote doesn't store the channel number if the signal isn't strong enough for the tuner to resolve. Analog channels can be added when the signal is poor.
If you know all of the local channels in each direction from AntennaWeb ( http://www.antennaweb.org ) or TvFool
( http://www.tvfool.com ), you can use that documentation to add the channels at each antenna direction.
I hope this helps. If you use an electronic antenna rotor with a remote control, you may be able to program turning the antenna automatically when you change the channel. Check the documentation for the device to program this.
(Note: on my TV that adds channels only when I type in the channel number, recorded digital channels can disappear from the list if if I visit a channel with poor signal strength. Until the antenna is directed towards that transmitter, I can't add the channel back into the list.)
Kenwood TM-281A cant set memory channels
Great to hear you have resolved the issue, Jason.
Cheers,
Peter
1helpful
Unable to turn on internal speakers. When I go to audio setup, states to hit enter to make changes. Hit enter and automatically exits setup?
This set does have a hard reset which is done with the original Mitsubishi remote, confirm actual model number and I will tell you how to do it.
It will return the set to the condition it was when new in the box, all labels on inputs will be gone, set should then come on channel three in AIR band; YOU HAVE TO AUTOPROGRAM it and put into cable band if using that.
Let me know model number.
SD TECH
13helpful
Dont know how to do a channel scan on my samsung 2333hd t.v
Using the Color buttons on the Remote with the Channel List.
• Red (Antenna): Switches to Air or Cable.
• Green (Zoom): Enlarges or shrinks a channel number.
• Yellow (Select): Selects multiple channel lists.
• TOOLS (Option): Displays the Add(or Delete), Add to Favorite(or Delete from Favorite),
Timer Viewing, Channel Name Edit, and Auto Program menus..
Auto Program
The TV automatically cycles through all of the available channels and stores them in memory.
In rare cases, "Auto program" may miss a few channels due to weak signals and the channels may
not be added to the channel memory.
Air
Cable
Auto
MENU → arrow up, arrow down→enter → arrow up, arrow down→enter →arrow up, arrow down →enter →arrow up, arrow down, arrow left , arrow right →enter → MENU,EXIT.
Hope this helps. I have the owners manual on file.
Add or delete channels on LXI tv
I have a Phillips LXI 46in TV. How do you save channels?
Can't view all my channels on LXI series TV
For anyone with a set with this problem that is older----IT DOES NOT HAVE THAT PART OF THE CABLE BAND BUILT INTO IT--only solution is either to put a cable box to it or buy a new set.
SD TECH
1helpful
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
i have the same model, so try going to menu and doing the add/delete channel thing....also i found that i only get all my channels if the tv is set to catv instead of tv
Adding a channel to TEAC television
Hi I had the same problem so I bought a cheap universal remote controller and tuned into this model.
Once it is done, press a number on the remote controller and you can start to tune manually.
I do not know about the solution for AV channel.
Pioneer projection tv model sd-p404
In menu go to cable/then press auto programming see if this fixes your set.
Wrong or 3-Digit Channel Numbers
that request is not available...firm-wared chip proprietary from orion
Top Pioneer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
