Question about Epson Stylus Photo R1800 InkJet Printer
Help! Prints a smeary mess!
I have an epson R800 photo printer, so this may be the wrong forum.   If anyone has any ideas, though, please let me know. Simply put, the prints come out very wet, smeary and unrecognizable.  What could be happening?
  • ITPhotos Feb 28, 2008
    Epson Picturemate PM240 Prints come out wet and smeary. Wait awhile and then it seems to work. Using recommended epson paper.
  • Epson Master
  • 1,879 Answers
It depends on the type of paper you are using.
ink chemicals react to the chemicals on the photo paper.
manufacturers have ¨recommended papers¨ : )
recommendation: ask for paper samples from paper vendors
Posted on Jan 03, 2008
I have an epson printer that says its connected but when I prints out blank
is it going through the motions of printing or is it just dumping the paper?
Check your print file to error if you have an notice
May 25, 2012 | Epson Stylus Photo R800 InkJet Printer
Purple line across top of prints
If its like alot of other printers its a warning sign your getting low on ink
Jan 07, 2011 | Epson Stylus Photo R800 InkJet Printer
I suspect this will be a tricky one! I am printing from a new iMac / CS5 setup. I am using OCP inks and Ilford paper. I am printing the same images to both machines. The print settings are identical....
hi Anthony, i spent a month trying to figure out a similar problem with an epson 2200. Now, the printers are different but not that much, and, the changes in paper and ink gave me "some" color issues but not as bad as what i was getting. your problem seems very similar. i run a PC so this is similar but not exactly the same. what i found was that a Magenta/ violet cast was due to double profiling. I could verify that i had the correct settings but i was wrong! I print from CS3 into the epson 2200. What i found was there is an error(no one is talking about) in the printer driver. You cannot shut off the color management completely! Assume this scenario, you are printing with CS3 applying your profile in CS3. Make the settings in CS3 as normal, then you are directed to the printer settings. Go to the print driver and make the selections for ICM Color, and select "no color". The KEY is to make sure you do this step LAST , make sure to click on the "apply" button, then "Close". Once you make the selection of "No Color" do NOT click on anything else. If you change screens in the print driver once you select "no color mgmt" the driver CHANGES your settings. ANY settings in the other pages in the print driver cause the driver to apply a printer profile, this effectively "double profiles" your photo print causing the magenta cast. None of this should happen if the driver was created correctly but there it is! It took a long time to test and verify but it is as i stated. Once i got it sorted out my photos are excellent ALL the time. Good luck, worm1855.
Nov 21, 2010 | Epson R800 InkJet Printer
Is there a maximum file size the r800 will print.
r click on printer go to preferences select second tab PAGE SETUP go to bottom and see OPTIONS and see if the printer data size spooler is ticked
this controls the amount of data sucked up into memory in any run. so printer will pause to take the next bytes of data to print.Instead of all the data in one hit
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Epson Stylus Photo R800 InkJet Printer
I HAVE a epson stylus photo R800 printer. I cleaned the printer head using both the automatic and manual settings. The test pattern improved greatly, but still leaves the seventh pattern incomplete. ...
if after doing 6 head cleanings and its still the same issue, that only means that the printer is already having a hardware issue, the printer is totally broken
Feb 11, 2010 | Epson Stylus Photo R800 InkJet Printer
I just bought a new HP home computer which runs Vista (64 bit), and need to upgrade the printer driver for my epson R800 photo printer. However, I can not download the driver from epson's web site, as it...
try adding the printer using the add printer wizard. look for the inclussive drivers installed on the vista operating system. that should solve the problem.
if not try to visit again the website then search for the 64bit edition is the site
Oct 12, 2009 | Epson Stylus Photo R800 InkJet Printer
Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
Aug 25, 2008 | Epson Stylus Photo R800 InkJet Printer
Epson r800 inkjet will not turn on
I leave mine unplugged overnight. Next mornig I plug it in, turn it on and restart Windows. Give it a shot.
Jan 14, 2008 | Epson Stylus Photo R800 InkJet Printer
Epson R800 prints very wet, very very smeared pictures
it depends on the type of paper you are using. it is how the ink chemicals react to the chemicals on the photo paper.
Jan 01, 2008 | Epson Stylus Photo® R800 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
144 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
