Mine was quickly removed from our boat after Katrina, the antena wire was cut and now it is time to reinstall, will a double waterproof antenna coupleing work to re-connect unit ?? or do i need to open and reinstall from antena, it will be difficult as raymarine used reg. steel screws that have disintergrated!!
Or is this a service issue, wrote raymarine with no response
That unit uses a TNC connector. Just have someone install a new one on the end of the cable. IT's a little more difficult than a F connector for a TV but not rocket science. You can also send it in to Mid-Shore Electronics. Just google them and get their number. They have alot of experience with the older stuff.
If the cable has no oxidation or it is broken
a double waterproof antenna coupleing work to re-connect unit will make it fine be sure that the conection is fine thru this cable goes 5V DC and high frequncy signal
