Samsung DynaFlat TX-P3271H TV. When auto selecting channels, it doesn't find the digital channels, 7.1, 7.2, etc on cable. It did when I was on an antenna. Other tv's I own have a place to select digital and/or analog, so I know those channels are available on the cable. I can't make it happen with the Samsung. It's an older tv - about 2002.
it is making a loud humming sound, changing the video mode or sound setting have no effect on the...
(More)
it is making a loud humming sound, changing the video mode or sound setting have no effect on the humming noise.
When I use the component jacks on my Samsung TX-P3071WH hdtv the screen turns green after a minute...
(More)
When I use the component jacks on my Samsung TX-P3071WH hdtv the screen turns green after a minute or so. I can hear some sound but I only get a green screen.
Hi-- I've got at TX-P3071WH Samsung CRT HDTV that i found on the street yesterday, and when I turn...
(More)
Hi-- I've got at TX-P3071WH Samsung CRT HDTV that i found on the street yesterday, and when I turn it on, it makes a high pitched noise, but doesn't come on. The noise is probably in the 10-12khz range, not as high as it would be if it were on, and the power light blinks.
I was told that this probably means the flyback is okay, but there is something wrong with the power supply. Do you have any advice, or know where I can obtain a copy of the service manual (for free....)?
thanks
Hello, Neighbor left TV when they moved out, anyways we set it up and once you turn the TV on...
(More)
Hello, Neighbor left TV when they moved out, anyways we set it up and once you turn the TV on there's no picture just a message that says AV. Went to menu under channels - tried to change from AV to TV and then ANT to CATV - it says "not available". Tried to change channels and it also says "not available". As for the volume, we thought it might be on MUTE but that is not the case. Help anyone!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
