Question about Bosch WFMC 2100 Front Load Washer
I have a bosch wfmc 2100 washer that doesn't drain
Hello.. I have a Bosch WFMC 2100 Front Load Washer.
it's not draining and it's my first washer.. I am unsure what to look for or what I should do. The ERROR code I get is E04. I hope someone can help me?
  • 43 Answers
Have a look on the Bosch web site, they offer solutions to some problems, if not contact them via email
Posted on Feb 12, 2008
How to change the door hinge
Link to PART:
Bosch Washer Hinge - AppliancePartsPros.com
http://www.appliancepartspros.com/bosch-washer-hinge.html
Link to VIDEO - "HOW TO REPLACE DOOR HINGE"
(scroll down half way at this link)
VIDEO: Washing Machine Door Hinge ' eSpares
http://www.espares.co.uk/product/es486275/washing-machine-door-hinge
Jul 09, 2014 | Bosch WFMC 2100 Front Load Washer
I have a Bosch WFMC2100UC101 washer that just stops in mid cycle. It may stop with 59 minutes remaining or 2 minutes remaining or anywhere in between. I have replaced the control board, but it didn't...
Its possible you have a blocked drain closer to the tub. Try tilting the machine to access underneath the machine and locate the drain pump. Then have a basin read to catch any water and remove the hose that goes from the pump to the drum and check for anything that may restrict water flow, possibly a sock. Hope this helps.
Feb 28, 2011 | Bosch WFMC 2100 Front Load Washer
Spin cycle will not engage ..
The machine is failing to empty completely, make sure drain hose is free to drain and the drain is not blocked and that the filter isn't blocked. Also make sure you haven't selected rinse hold
regards
Feb 01, 2011 | Bosch WFMC 2100 Front Load Washer
Bosch Nexxt Essence WFMC 2100 UC (washing machine) Water leak noticed on floor right in front after wash cycle is completed. This occurs every time I use the washer.
Bosch Nexxt Essence WFMC 2100 UC (washing machine) Water leak This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 26, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
We are getting error message E04 on our Bosch front loading machine and it won't drain and it makes a grinding sound.
We removed the round panel in the front and there was a knee hi stocking stuck in the filter - great advice - it's fixed and working perfectly.
Jan 03, 2010 | Bosch WFMC 2100 Front Load Washer
Borch wfmc2100 watersoftner not draining
this is joyce
This will happen, I also have a front loader machine it also does this I just empty it out and start over every time. the water pressure is so strong that it leaves some in resorvor.
thanks
joyce
Feb 06, 2009 | Bosch WFMC 2100 Front Load Washer
Bosch WFMC 3200 Front Load will not pump water out
the pump gears could be stripped or clogged with soap residue including the line from the pump to include the drain hose itself. I took the back of my machine off after cleaning the pump twice to find the reservoir full of a brown soap gunk/sludge. there is also a small rubber tube that runs from this reservoir back into the drum which was plugged shut with the same gunk. this thick soap residue can damage the pump motor or slow the drainage system to get the E 04 warning. I cleaned the gray drain hose out with the garden hose and was amazed at the sludge that game out. When the machine would run on the drain cycle we would also get a sewage smell that I thought was coming form the drain trap but turned out to be caused by the sludge in the pump. After cleaning the system and now using no more that a tablespoon of soap it works great & the cloths are clean.
Dec 18, 2008 | Bosch WFMC 3200 Front Load Washer
Washer wont drain or spin
As long as the water is draining away okay,then it sounds like new carbon brushes for the motor are needed if belt is ok.Should cost 10 pounds or so for replacement.Turn off power via socket before removing belt and motor.Good luck...
Aug 27, 2007 | Bosch WFMC 3200 Front Load Washer
E04
Perhaps try opening the round panel on the front of the machine at the bottom and cleaning that hose...good luck because it might be messy.
Nov 19, 2006 | Bosch WFMC 2100 Front Load Washer
Open Questions:
Bosch WFMC 2100 Front Load Washer Logo
640 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
