Question about Canon PIXMA MP510 All-In-One InkJet Printer
My MP510 grabs way to many sheets of paper.
Every time I go to print using either the front loader or Auto sheet feeder, (this goes for plain paper or photo paper).my printer wants to grab anywhere from 3 to 6 sheets of extra paper.
1. I have tried switching the envelope/paper switch..................
2. Ensuring only fresh straight paper is used in either of the feeders.
This is frustrating as there doesn't seem to be much in the way of adjustment for this issue.
(It has done it since the day I bought it.)
Thanks in advance, Thom R.
  • 52 Answers
Hi i am a Canon certified repair tech for this printer. it seems that your problem is due to a broken sheet feeder unit. what i ahve seem with some new machines is that a plastic shaft that controls ther seperation of the pages breaks. most of these problems occurs with new machine because they are shipped from place to place. if the unit is under a year old it is still under warrenty and can be brought to or shipped to a repair center. even if its not under warrenty any longer you should still call Canon at 1-800-OK-CANON and complain that it has been doing it since you bought it and they will locate the nearest repair center to your location for you. hope this helps.
Posted on Jan 05, 2008
How do I print an envelope on my Canon MP510?
Envelopes must be fed from the Auto Sheet Feeder. Use either European DL or US Comm. Env. #10-sized envelope.
Important :
  • You need to print from the computer to print on envelopes.
  • Do not use envelopes with embossed or treated surfaces, a double flap, pressure seals, or sticker flaps.
  • Select either DL Env. or Comm. Env. #10 in the printer driver according to the envelope size you are using. If you do not, the address will be printed in the wrong direction.
1 : Retract the Paper Support.
2 : Load the envelope against the Cover Guide (the right side of the Paper Support).
Load with the front face UP and the rear flaps DOWN on the left.
A maximum of 10 envelopes can be loaded at once.
*1 Printing orientation
*2 Make sure the flaps are folded.
Important : Make sure that the Cover Guide is set upright.
3 : Pinch the Paper Guide and slide it against the left side of the envelope.
4 : Press the Paper Feed Switch so that the Auto Sheet Feeder lamp lights up.
5 : Set the Paper Thickness Lever to the right.
In the printer driver, select 'Envelope' in Media Type, and then select 'DL Env'. or 'Comm. Env. #10' in Page Size.
Jun 21, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Canon ip1800 is experiencing paper jam.whener tries to print, cannot feed the paper properly
Sometimes a printer just needs some cleaning.
Remove the jammed paper following the procedure below. (1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the Paper Output Slot, whichever is easier.If the paper tears and a piece remains inside the printer, turn the printer off, open the Front Cover, and remove it. Be careful not to touch the components inside the printer. After removing all paper, close the Front Cover and turn it back on.If you cannot pull the paper out, turn the printer off and turn it back on. The paper will be ejected automatically. (2) Reload the paper in the printer, and press the RESUME/CANCEL button on the printer. If you turned off the printer in step 1, all print jobs in queue are canceled. Reprint if necessary.
Make sure to clean the paper feed rollers if paper is not fed properly. Cleaning the Paper Feed Roller of the Auto Sheet Feeder consumes it, so perform this only when necessary. 1. Make sure that the printer is turned on, and then remove any paper from the Auto Sheet Feeder. 2. Open the Printer Properties dialog box. 3. Click the Maintenance tab and then Roller Cleaning. 4. Confirm the message, and then click OK.The Paper Feed Rollers will rotate as they clean. 5. When the message appears, load three or more sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder.Set the Paper Thickness Lever to the left. 6. Confirm the displayed message and click OK.The paper that is loaded in the printer will feed through the printer and be ejected. 7. When the confirmation message is displayed, click OK. If this procedure does not solve the problem, clean the surface of the roller with applying a slightly moisten cotton swab with water to wipe off dust or stain.
If the problem still persists, contact a Canon service representative.
Mar 28, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
My printer says it's out of paper, but it's not.
once y0u have pressed print button and you printer starts up push the paper further into the loader so the feeder can grab the next sheet of paper, mine did this a few times then went back to working normally
Oct 07, 2010 | HP Office Equipment & Supplies
Hello can you assist I can not figure out why the CX8310 Epson printer won't allow me to feed paper into it.
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right edge, behind the tabs, then slide the left edge guide against the paper. Make sure the paper is not in front of the feeder guard.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • Don't load too many sheets at once (up to 20 sheets of photo paper, 80 sheets of Premium Bright White paper, or 100 sheets of plain paper).
    Sep 11, 2010 | Epson Stylus CX3810 All-In-One InkJet...
    My praftically brand new Canon Pixma MP620 printer grabs more than one sheet of photo paper and stops printing picture on first sheet then garbles several pictures on a portion of the next sheet. I just...
    check the printer's printing preferences on properties option.should be set to normal then check the printer rollers if its dirty where the papers pass thru, if the problem persists load only 1 paper every time you print for the printer not to grab more papers.i think it is in the feeder and the sensor maybe its dirty need to be cleaned up.
    Feb 22, 2010 | Office Equipment & Supplies
    Paper won't feed
    Inside of the machine is dirty.
    If the inside of the machine is dirty, the printed paper may be smudged.
    Follow the steps described below to clean the inside of the machine.
    1. Ensure that the machine is turned on and there is no paper loaded in the Auto Sheet Feeder.
    2. Place A4/Letter-sized plain paper in landscape orientation, horizontally fold it in half.
    3. Unfold the paper, and load the paper in the Auto Sheet Feeder with the inverted-V edge down.
    4. Select <Bottom plate cleaning> from <Maintenance>.
    5. Select <Yes> on the Bottom plate cleaning confirmation screen and then press [OK].
    Paper will be ejected.
    If protrusions inside the machine are stained, wipe ink off the protrusions using a swab or such like.
    * Important
    Before cleaning, be sure to turn OFF the machine.
    Paper feed roller is dirty.
    Follow the steps described below to clean the paper feed rollers.
    1. Ensure that the machine is turned ON and there is no paper loaded in the machine.
    2. Select <Roller cleaning> from <Maintenance>.
    3. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
    The paper feed roller will rotate as it cleans.
    4. Repeat this operation twice.
    5. Load three or more sheets of A4/Letter-sized plain paper lengthways in the Auto Sheet Feeder.
    6. Select <Roller cleaning> from <Maintenance>.
    7. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
    The paper that is loaded in the machine will feed through the machine and be ejected.
    8. Repeat Steps 5 to 7 three times.
    Inappropriate paper type is used.
    Check to see if the paper you are printing on is too thick. See Paper Types You Cannot Use.
    Note that smudging may occur at the top and bottom edges of the paper when using Borderless Printing. Ensure that the paper you are using is compatible with Borderless Printing.
    Thick paper is used.
    When printing on thick paper, set the Paper Thickness Lever to the right.
    This widens the gap between the FINE Cartridge and the paper. Try this maneuver if the printed surface is scratched.
    Media is curled.
    If all four corners or the printing surface of the paper is curled, the paper may become dirty or may not feed properly. Use the paper after correcting paper curl as follows.
    1. Place the printing surface face up (A), and cover it with a sheet of non-printing regular paper to avoid damaging the surface.
    2. Roll up the paper in the direction opposite to the paper curl as per the figure below.
    3. Check the printing paper to confirm if the paper curl is eliminated to within approximately 2 to 5mm / 0.08 to 0.2 in (B).
    It is recommended to print on curl-corrected paper one sheet at a time.
    The media type is not selected correctly in the printer driver.
    On the [Main] tab of the printer driver, ensure that the [Media Type] selected matches the paper loaded.
    In the [Print] dialog box of the printer driver, select [Quality & Media] from the pop-up menu, and then ensure that the [Media Type] selected matches the paper loaded.
    Paper is loaded incorrectly.
    Load in the portrait orientation regardless of the print direction of the Auto Sheet Feeder.
    Ensure that paper is loaded correctly. Slide the paper guides against the paper stack.
    Oct 18, 2009 | Canon Pixma MP500 All-In-One InkJet...
    Will not print
    Cleaning the Interior of the Machine If the interior of the machine becomes dirty, paper printed onto by the machine may get dirty, so we recommend performing
    cleaning regularly.
    Note: Ensure that the Inner Cover is closed.
    1. Press <ON/OFF> to turn on the machine, then remove any paper from the Auto Sheet Feeder.
    2.Press the Open button to open the Paper Output Tray, and open up andset the extension by pressing down the hollow on the front side.
    3.Prepare a single sheet of A4- or Letter-sized plain paper. Fold it inhalf along the long edge. Unfold the paper, then load it in the AutoSheet Feeder with the open side to the front.
    insertfoldedpaper.gif 4. Start bottom plate cleaning.
    1. Press <COPY>.
    2. Press <Menu> repeatedly to select [4.MAINTENANCE].
    3. Use [left.gif ] or [right.gif ] to select [BOTTOM CLEANING], then press <OK>. The sheet of paper is automatically fed in and then out of the machine.
    Ifthe printed paper is smudged, clean the inside of the machine again. Ifthe problem remains after performing cleaning again, the protrusionsinside the machine may be stained. Clean them up.
    Note:Even if the Cassette is selected as the paper source, paper will be fedfrom the Auto Sheet Feeder. Do not perform any other operation whilethe bottom plate is being cleaned.
    Cleaning the Protrusions inside the Machine
    If protrusions inside the machine are stained, wipe ink off the protrusions using a swab or the like.
    I hope it helps!!!
    Nov 13, 2008 | Canon PIXMA MP530 All-In-One InkJet...
    Canon Pixma mp510
    The top-loading sheet feeder accommodates approximately 150 sheets (depending on weight), and the front feeder is good for around 100 sheets. Actual media sizes supported by the main feeder (top-loading) include A4, B5, A5, Letter, Legal, Envelopes (DL size or Commercial 10), 10x15cm(4" x 6"), 10x18cm, 13x18cm, 20x25cm, and Credit Card (54x86mm), while the front feeder is less accommodating with just A4, Letter, and B5.
    Jan 27, 2008 | Canon Pixma MP500 All-In-One InkJet...
    Can't change image quality
    The problem is that only "fine photo pro" is available when the paper selected is photo paper. Change source to the sheet feeder, hit the "Paper" button and then select normal paper. You'll then be able to change the quality to normal.
    Sep 22, 2007 | Canon PIXMA MP780 All-In-One InkJet...
    Canon PIXMA  MP510 All-In-One InkJet Printer Logo
    122 people viewed this question
    old marine
    old marine
