Question about Frigidaire FWS1339A Top Load Washer
Drum dropped The drum on my frididaire washer dropped about an inch, it still spins but makes a horrible noise. Can this be a do it yourself job?
  • termit Jan 02, 2008
    Yes we can lift the drum up, any tips on easy removal.
    Thanks so much.
    termit
  • termit Jan 10, 2008
    I appreciate all your help and yes I did manage to fix it! My hubby was impressed...i did it while he was at work, it was a $2.00 bolt under the drum!
    This is the best site...thanks again.
    Jenn
    Scholar:
  • 196 Answers
Are you able to lift the inner drum back into position ? If so then the culprit is most likely within the trunnion or spin bearing assemblies. Dis-assembly can be tricky but it is possible to do this yourself.
Posted on Jan 02, 2008
  • Elmer Vest
    Elmer Vest Jan 10, 2008
    Sorry it has taken so long to respond. Faulty internet connection. Do you need a step-by-step guide to disassemble this unit?
Washer making noise in the spin cycle sounds like a roller or a baring
if its it sounds like a plane engine starting up its the bearings in the rear tub its quite a large job to do, if its a horrible crunching/banging noise one or more of the spider arms has broken on the rear of the drum which is much worse than bearings as it often causes damage to other things
Jan 30, 2017 | Washing Machines
Kenmore elite washer troubleshooting
Sounds like your bearings are worn and need replacing... a horrible job. The frayed plastic may mean a new drum. To replace the bearings you must remove and separate the drum which requires removing the top, front, and back panels. Lots of clips, screws, hoses, wires.... I'd take it on if this were my unit; but for a client, I'd say get a new one. This is not uncommon for these units. Sorry.
Feb 16, 2014 | Washing Machines
LG direct drive washer makes loud grinding noise
Check presence a stranger subject in drum. Shine the torch and swing the drum.
If rubbish no that necessary to change the bearings.
Nov 12, 2013 | LG Washing Machines
My TAWS800JQ1 washing machine drum seems like it has shifted and is off balance
The bearings are likely shot. But it's possible the spanner nut that holds the basket in place is loose or damaged. Remove the agitator to check spanner nut. Changing bearings is a big job, but if you are handy with tools and good at keeping your cool you can do it yourself.
Jan 06, 2013 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Drum appears to be loose and makes a lot of noise when on the spin cycle
With the washer empty, spin the wash tub by hand. The drum should be spin true without any noticeable wobbling and spin without much noise. If it wobbles or makes any kind of rubbing or banging noise as you turn it by hand. The problem is that the spider support arms are broken. It is an expensive repair job since the washer has to be completely torn apart and the wash drum needs to be replaced. Get a few estimates before deciding whether to repair or replace. Sorry.
Mar 08, 2011 | Whirlpool AWM6100 Front Load Washer
Drum is loose when it spins it make a horrible noise pounding
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Nov 18, 2010 | Kenmore Elite 45986 Front Load Washer
Washer dances out of control in spin cycle until it pulls cord out of wall. Makes a horrible noise.
have the transport bolts been removed? there will be some transport bolts and spacers to be removed from the back of the machine that holds the outer drum still.(3,4 or 5 depending on model, I am unfamiliar with this one) remove these and make sure the spacers drop clear from underneath, 1 for each bolt.
Oct 04, 2009 | Frigidaire Affinity ATF7000E Front Load...
Dryer noise
open the door and if u can lift the drum up or down more than an inch the drum bearings are worn out. big job to repair unless under warranty.
Feb 07, 2008 | Dryers
Hotpoint washing machine
this is your that are gone these are at the back of your drum on the inside if these are gone then these will need replacing by a professional its a complete strip down aswell as stripping inner and outer drum apart from each other but this is a costly job £125+sometimes more economical to replace the washer only £100 more to get a new washer and have 12months warranty this way also if you have it done you will lose your washer for about 3days. to make sure they have gone take the lid off and look down to the middle of the drum at the back there should be some rusty water marks going down the drum also you can place your fingers to the inside of the washer while having your palm on the front of the washer if it lifts its the bearings from what you say though it will be the bearings m8
Oct 16, 2007 | Hotpoint Aquarius WD63 Front Load...
Frigidaire FWS1339A Top Load Washer Logo
407 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
