Washing machine leaks from bottom
As soon as I turn on the machine, water will start leaking out from the bottom, maybe center left. I am not overloading and it is level. Something on the bottom may have been damaged while my friend was putting it on the truck.
Any help would be appreciated.
  • 1,294 Answers
Open up behind after pluging off the wall. Check the hose that comes from under the tub, likely it is damaged or slipped out. Refit or change if damaged. You need a good pair of pliers; dont forget to insert the grip clips well.
Posted on Jan 02, 2008
Top loading washer leaking water during spin cycle
a few things could be causing this
(1) a hole has rusted thru your outer drum or maybe a dispenser line has come off inside
(2) some left over from a past wash cycle has gotten into the seal in the center agitator bearing and made it leak
(3) the dishcharge water pump has a leak in it
all these things can be routed out with just a strong flashlite and a little time to watch where water runs from during a cycle
Nov 14, 2015 | Washing Machines
My GE topload washing machine is leaking
Check the hose that connects to the bottom of the tub to the drain hose. Make sure that hose is securely fastened.
May 29, 2012 | GE Washing Machines
I have a kenmore top load washing machine model 110.92597200 that started leaking during the rinse cycle. The drain pipe isn't leaking and the water line hoses are just a few months old. They were both...
most likely is the water pump. you need to remove the cabinet to get to it and is at the bottom center. a white looking part. the shaft seal is bad.
Feb 09, 2011 | Washing Machines
Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Jan 04, 2010 | GE WSXH208A Front Load Washer
Leaking below washer
Sounds like you have a leak from the tub. Either the seal in the bottom of the tub or a hole in the tub.
When you run it again try feeling around the bottom center of the tub for water or try to see if water is leaking any where out of tub. Clear water would be from the supply line , soapy water would be from tub or a hose coming out of tub.
Jun 09, 2009 | Washing Machines
Top loading washing machine leaking at center bottom
remove panel below door and run it. Then you can see if it is the front seal or back at pump. Two screws on bottom of panel to remove it
Apr 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer leaks from bottom as soon as it starts filling with water
There are 2 green clips between the top of the unit and the front panel. (you can use a flash light to find them easier). Push on the with a putty knife or small flat head screw driver while lifting on the top. Once the top is open, you will find 2 5/16 screws that hold the front panel on at the top on the right and left hand sides. Once these are removed, you can tilt the front panel forward and see where the water is leaking from.
May 31, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Water is leaking out from the bottom
it could also be the pump thats leaking pump is on the right side at the boyyom tip it up against the wall with some water if its the pump you will be able to see it if it leaks replace the pump thanks THE APPLIANCE DOC
Apr 10, 2008 | Frigidaire CWS3600AS Top Load Washer
Washing Machines Logo
155 people viewed this question
Top Washing Machines Experts
