Gold Medal 2086 Popcorn Maker
Thermostat hook up
posted by sigakeyes on Jan 01, 2008
need wiring diagram for re hooking wires to thermostat
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 25, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
You can either call Gold Medal at 1-800-543-0862 or fix it yourself. There are only 3 wires going in. 2 are hot and 1 is the ground. All you need is a volt meter to determine the ground, and the other wires hook up as follows: 1 wire goes to one side of the heat element, the other wire goes to one spot on the thermostat. Then there's a jumper wire between the heat element and the thermostat.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on thermostat hook up:
I don't want to Accept this solution
Solution #2
posted on Feb 04, 2008
Not Rated (0)
joe40
Rank:Guide Guide
Rating: 93%, 18 votes
I actually just had a pleasant experience contacting Hellman Group, (The manufacturer of Nostalgia Electric popcorn machines). I called the main number, pressed 1 for customer support, and after 3 tries (got an answering machine the first couple of times), I got someone in customer service who was able to help me get the part I wanted. Not sure if they can give you a wiring diagram.
The Helman Group, Ltd.
1621 Beacon Place
Oxnard, CA 93033
Thank You!
Can you Help with these Popcorn Makers problems?
Popcorn Makers
Hi i need to see a diagram of the inside heating element...
Popcorn Makers
how many oz. is the star model 59 popcorn popper?
Popcorn Makers
I need to find a replacement bulb for my Circus Cart...
Gold medal #2408 popcorn jams up under stirrer and burns...
Hi just wondering if you could tell me why the gears that...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Help us help you.
Take a brief survey and help us improve the site.
Your opinion counts!
Repair Service
Find Popcorn Maker Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
