Question about Canon Selphy CP510 Thermal Photo Printer
Printing marks Hi I have had my My Canon Selphy CP510 for 1 year now. It has just recently started printing white 'dash' marks across the bottom of all the pictures. Do you know what this could be?
  • photowiz Jan 01, 2008
    I have tried 2 new ink cartridges as well as changed the photo paper. this has not helped the problem. It almost looks like a roller is placing 8 white dashes across .75 cm from the bottom of each photo
  • Globetrot Jan 06, 2008
    I have the same problem but it is not white dashes but a line across all pictures I print. It is about 1 cm from the bottom. Tried to change ink cartridge but that did not solve the problem.
I had issues like this, and changed to thinner paper. That solved my problem
Posted on Apr 08, 2008
My ink cartridge is stuck. I tried to turn it off and on again and to push the paper leveler down but nothing helps.
My Canon Selphy CP740 start to jam ink ribbon and ink - Fixya
Jan 4, 2013 - My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. ... Question about Canon SELPHYCP740 InkJet Photo Printer .... SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7.
Selphy CP740 - Catridge Eject Solution - YouTube
? 0:46
Sep 11, 2013 - Uploaded by Mahadhir Shaarani
Selphy CP740 - Catridge Eject Solution. Mahadhir Shaarani ...Replacing Ink for Canon Selphy - Duration: 6:23. Jenuine Crafts... How to Print Different Sizes with the Canon Selphy Printer - Duration: 12:08. Janet Wakeland ...
Color ink cassette stuck in canon selphy 'Canon SELPHY ...
Feb 03, 2016 | Canon Selphy Cp800 Compact Photo Printer -...
Canon selphy 710 printing only bottom half of photo. how to correct this?
Hiya Jeannie it sounds like you may have overwinded your ink sheet as that makes it impossible to print to all the paper....hope that helps.
Mar 08, 2015 | Canon SELPHY CP710 Dye Sublimation Printer...
Only half of the picture prints on my selphy cp 730 canon printer
Nov 01, 2014 | Canon SELPHY CP730 Thermal Photo Printer
Problem in setting the printer spooling of my two cp800
1-800-243-0019 Call on our Toll Free Printer Support Number and we providing best service for resolve all printer spooling of my two cp800 issues.
Apr 14, 2017 | Canon SELPHY CP800 White Compact Photo...
My cannon Ds810 Selphy has started printing all my pictures in orange. I have tried changing the print cartridges twice, I have tried automatic and manually it, cleaning, deep cleaning, cleaning the bottom...
Hi Kate,Sounds like you're in a bit of trouble there. The only solution is to only print things that are actually orange. The following are some suggestions. Oranges (obviously), Foxes that are more orange than red, Swimming armbands, Carrots, Those cheap bic razors, Herbal essences volume conditioner, Hi vis vests (orange not yellow!!!), People with ginger hair and self tan, Orange juice, etc...If you need any more help wikipedia will surely have a list of things that are orange.Kind regards
Oct 24, 2011 | Canon SELPHY DS810 InkJet Photo Printer
Selphy DS 810. Shows error code 5100. I want to
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Only gave it a go
All The Best: Pineworks
Nov 19, 2009 | Canon SELPHY DS810 InkJet Photo Printer
Question Mark Appearing on Canon Selphy printer screen
I encountered this issue with a Selphy CP800 and I presume the reason is the same; it seems to be a common problem. Canon tech support says that Selphy printers need exif data "just so" in order to generate screen previews. If all you do is copy your image to a flash memory device from your camera card, you may well be OK. But if you edit the images (e.g. in Photoshop) you will very likely alter the exif data so that Selphy cannot generate previews from flash media plugged into Selphy. If you are copying images back to a **camera** SD card you may also have to make sure that you don't alter the file structure already present on the card. There are undoubtedly other ways to louse up the exif data of an image so that you can't get a screen preview. Workarounds: 1) official Canon advice is to print the image directly from your computer - that's what tech support told me; 2) if you own Canon's Digital Photo Professional Software you can rebuild the exif data by using File>Convert and save>kind of file = exif-jpeg - this worked for me; 3) Graphic Converter for Mac now has a way of rebuilding exif data according to a poster on the Apple discussion boards; I could not test this out b/c my (old) version of Graphic Converter, 5.4, does not have this capability; 4) if you get a screen question mark, the image will still print - you just can't see the preview. This is only a problem if there's more than one image that generates a question mark on your flash media device because you can't see what image you're printing. So if all else fails and you have to print from flash media, you can put a single image with screwy exif data on a flash drive and be confident that you know what you're printing.
Jul 30, 2009 | Canon SELPHY CP740 InkJet Photo Printer
Canon Selphy 510
Hi! I have same problem. I opened cover (4 deep screws at the bottom) and found small plastic gear was separated from stepping motor shaft. I fixed it on shaft and my printer started work again. Today I will try to fix same problem on another CP510. I think same reason. Try to do it. Simple.
Feb 29, 2008 | Canon Selphy CP510 Thermal Photo Printer
Canon Selphy CP510 Thermal Photo Printer Logo
266 people viewed this question
old marine
old marine
