Question about Pioneer PD-F1009 301-Disc CD Changer
Pioneer 301CD Player PD F1009 disc tray jammed
The CD's in my PDF1009 Pioneer CD player won't advance. The selection wheel spins normally and the screen shows the numbers advancing but the disc tray doesn't go forward or backward. I removed all the CD's (opened the case - gasp!!!) but nothing was stuck. No error message on front either. Only 2 yrs 2 mos old (out of warranty naturally....). Any advice would be helpful.
Ray
sullray26/at/yahoo/dot/com
  • 4 more comments
  • LennyC Mar 07, 2008
    Have a pre-owned, but lightly used Pioneer PD-F1009, and found a software program to catalog my CD collection on my laptop (called MusicCollector from Collectorz.com).
    Loaded up over 200 CDs, and was giving the random play a workout, when after about 20 tunes, WHAM, I heard a loud popping noise, and the machine stopped rotating the carousel. The electronic cues still performed, but nothing moved except the main door. I searched for a solution in the owner's manual, and there was nothing like this described. Found this RixYa blog, and the description of the problem, and the solution looked identical.
    When I opened the cover, I saw one CD was loose in the player (center), and because I had a catalog and could read the title, I could see which slot it belonged in. I carefully rotated the carousel by hand, until the right slot was aligned with the feed chute, and eased the CD out of the center back into its own slot. Then, I followed the advice of the genius who posted the solution, and moved the white lever back into its slot in the black housing.
    Everything is working again, thanks to you fellas. Thanks for taking the time to share your knowledge.
  • Anonymous Jan 13, 2009
    I have a similar problem.
    I have had this unit for several years and it worked perfectly. I only used one CD at a time as that is all I needed. However, yesterady, in playing a CD, I also heard a loud popping noise and the volume changed.
    So I stopped the machine and tried to check it and eject the CD. The CD just fell and I had to retrieve it.
    The electronic cues still performed, When I opened the cover, I saw one CD was loose in the player I also carefully rotated the carousel by hand, until the right slot was aligned with the feed chute, and eased the CD out of the center back into its own slot. There is a black lever that falls down in front of the CD, I assume to guide it into the playing slot, but the CD does not get pushed forward.
    I noticed that when I tried starting the CD again, I could see the CD getting aligned, but it doesn't get pushed forward, so it just doesn't start. Opening the door I will either find the CD on its side or held in place.
    CAN I FIX THIS MYSELF.... PLEASE HELP.
    I have had this unit for a few years with no problems. However yesterday, suddenly WHAM, I heard a loud popping noise. The electronic cues still performed but the volume changed so I stopped the player and tried to check it and remove the CD. It fell on its side when I opened the cover so I carefully rotated the carousel by hand, until the right slot was aligned with the feed chute, and eased the CD out.
    It does the same thing now each time I try to play it. The CD rotates to the left where it should be pushed forward into the play slot but it just stays there. It is not being pushed in.
    CAN ANYONE HELP ME ON THIS…..
  • Daniel Evans Jan 13, 2009
  • jfishe6507 Mar 15, 2009
    Yes! Can't give enough thanks to those who posted a solution and it worked like a charm!
  • Anonymous Mar 31, 2014
    cd player locked and cannot get 25 cd door to open
I had this same problem today on my pd-f1007
unplugged it
took off the cover screws ..2 on each side and 3 in back on top
in the middle of the unit there is a white arm with a tab on both sides
it lifts the cd into the middle to be played
the white tab had come out of the slot it was suppossed to be in on the black cd arm
just carefully ease the tab back into the slot and its like new
Posted on Jan 06, 2008
  • JeffP
    JeffP Oct 31, 2013
    I too had same problem with my Pioneer Elite PD F27. Located white tab and rotated while inserting tab into black cd slide piece. No sooner than you can say Bobs your Uncle, we're golden. Nice fix for saving some green. Thank you.
I just can't believe it. The solution WAS PERFECT.
I had to look for that white arm and it took a little
guess work on how it worked.
But my god, he is right. Hold the black Upper arm that moves
back and forth to load the cd, and push on the white tab piece,
until it pops back in. Just be careful not to put too much pressure on it. It will pop in if you have it right.
THANK YOU THANK YOU THANK YOU ss123.
Posted on Jan 14, 2009
I can't believe it either - had exactly the same problem as ss123 and took solution from mrdb - 10 minutes later my CD player was operating normally! Thank YOU!
Posted on Nov 09, 2011
Pioneer PD-M501 6-CD Player manual and what magazine cartridge
The standard cartridge for the Pioneer PD-M501 is the Pioneer JD-M300 6-disc magazine, and you can find them at Amazon.com for $25 new. The JD-M300 fits a lot of different brands of CD players, not just this particular brand and model. And here's a link to a copy of the owner's manual: http://www.scribd.com/doc/22613342/Pioneer-PD-M601-M551-M501
Mar 26, 2010 | Pioneer PD-M603 6-Disc CD Changer
Turned on my Pioneer PD M501 one day and it would not play. Disc tray will not retract into cartridge and cartridge will not eject.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams.
Make sure your tray retracts all the way into the player flush with the face plate, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM and others.
Feb 18, 2010 | Pioneer PD-M603 6-Disc CD Changer
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
Many Magnavox, Denon, JVC,
Dec 04, 2009 | Pioneer PD-M426 6-Disc CD Changer
The pd-f1007 301 disc player was working fine yesterday, and this morning i turned it on,, and the display didn't come on, and the tray just keeps spinning very slowly, any ideas
You may need to take the backing off of the player to check if any cds might have jamed in the actual cd player. i have one similar to this that jams because of one cd that is a little bit larger then the other.
Jun 21, 2009 | Pioneer PD-F1007 301-Disc CD Changer
Pioneer PD-F907 CD wont play most of the time
MOST LIKELY IT SOUNDS LIKE THE MOTOR THAT SPINS THE DISC - NEEDS REPLACING
Jun 26, 2008 | Pioneer PD-F907 CD Player
Pioneer pd-m406 cd changer magazine style
The Pioneer component 6 CD magazine changers only play normal store bought CDs, not CDs you make yourself.
sorry.
Nov 03, 2007 | Pioneer PD-M406 6-Disc CD Changer
Pioneer PDR-W839 Jammed Disc Changer (previously posted)
hello poopig1, after further review, I meant to describe this: look for a pinhole in the area of the CD tray to insert a pin...similar to the same pinhole you see on a PC's cd player to eject the tray manually. If there is none, then try this: Open the cover and find the motor that, when turning, performs the tray ejection. Then, turn that motor by hand until the entire tray (or cartridge) is ejected. Then power up and observe the events.
May 31, 2007 | Pioneer PD-RW839 4-Disc CD Recorder
PD-F505
try a lens cleaning cd,if this doesnt work is more than likely optic (laser) faulty as laser has to focus first before spinning disc.if it cannot focus disc will not spin..
May 15, 2007 | Pioneer PD-F505 CD Player
Pioneer PD-F1009 301-Disc CD Changer Logo
1,247 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
