Question about Hotpoint VBXR1090D Top Load Washer
Hotpoint washer , top load
We have a new Hotpoint washer and it works fine, except that if we want to wash a load of whites on hot water and cold rinse, the water comes out warm. If we shut off the cold water the hot water comes through fine, but not when they are both turned on. Do you have a solution??
    Scholar:
  • 196 Answers
This sounds like a faulty water valve. Water is coming in the cold water valve when it shouldn't. If the machine has an automatic temp control make sure it is turned off.
Posted on Jan 02, 2008
Washing machine not heating
PLEASE CHECK THE WATER COMING TO THE FRONT WASH FRONT LOAD WASHER DONT HEAT THE WATER IT AS A HOT AND COLD WATER VALVE CHECK WATER VALVE
May 02, 2014 | Hotpoint WMA50 Front Load Washer
Will this machine work with just a cold water supply
It should work with a cold water supply WF865 hotpoint if it has one connection on the back it is a cold fill machine all new machines are cold fill only hot fill has gone now. hope this helps.
Dec 27, 2010 | Hotpoint Ultima WF865 Front Load Washer
No cold water to my Maytag Top loading washer
Pull the washer out from the wall and disconnect the water lines from the washer. Check to see if a build-up of minerals is clogging the screen on the cold water line where it enters the washing machine.
May 14, 2009 | Maytag PAV2300 Top Load Washer
Hot/cold cycle works but w/out hot water
I got my washer from a friend and his did the same thing. I have to put the washer on normal for cold water and heavy load for hot water.
Apr 15, 2009 | Hotpoint VBXR1090B Top Load Washer
Haier Genesis HLT364XXQ CAN'T GET HOT WATER WASH
hey Paul, you don't have to wash anything in hot water. Hot water only wastes money and does nothing, in my opinion, to get anything cleaner. It does ,however set the stains. To kill any thing the water has to be 212 degrees [ boiling ]I have not used hot water for over 40 years and our clothes are coming out clean. Just set the machine on cold. I put a twoway spigot on my cold tap and put the hot water and cold water together incase someone breaks in and does my laundry. Barry
Feb 14, 2009 | Haier HLT364XXQ
Maytag washer will not rinse on the white cycle. is it the timer?
you must know that because it sets there and dose nothing???if so it has to do with water[its calling for it and its not coming so it keeps waiting,cant move on till sattifies the water level switch].set timer at start of load and check water setting temps .dose cold come out when set cold only also same hot.ihope thats a bit of help.God bless ,tom
Jan 04, 2009 | Whirlpool GSC9455 Top Load Washer
COLD WATER WASH
Turn water cold water valve off by hose. Unscrew hose from both ends. Clean out filter inside the end of the washer water valve where the hose was connected to the machine. Check to make sure there is not a screened washer in either end of the hose which may also need cleaning. Reattach and turn water back on.
Oct 11, 2008 | GE WBSE2090A Top Load Washer
GE washer
replace the water inlet valve
Jun 10, 2008 | GE WBSR3140DW Top Load Washer
Hotpoint BWM129
hi there,
try the following, it may help:
Some washing machines allow hot water to enter only during certain cycles. Others intermittently
allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual
if you are unsure about whether the machine is acting abnormally.
If you're sure the machine isn't working the way it used to--or should--try these tests:
* Is the hot water turned on? If not, turn it on.
* Is the washer getting cold water but no hot water? If so, check to see if the control panel
settings are correct.
Apr 18, 2008 | Hotpoint BWM12 Front Load Washer
Hotpoint VBXR1090D Top Load Washer Logo
120 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
