Question about Motorola Mobility RAZR V3m Cellular Phone
My Razr Wont Get Enough Service to Call
When i go to make a call or send a txt message it says that i have service, like 3 or 4 bars. But then when i go to make the call it never connects and i loose all my service bars. The same thing happens when i go to send a txt message. I know that there is service in those areas because when i first got my RAZR i could call and do whatever from that area and nothing ever went wrong, And if i ever do get any service then i most likely drop the call. What should i do to fix this problem and how.
Thanks
  • Anonymous Jan 01, 2008
    how do i unlock my rzr v3 for all services
How do i unlock my rzr v3 thnx
Posted on Jan 01, 2008
6ya staff
SOURCE:
I cant send txt msg, my service center number is gone, i think i need the service center number? [email protected] network
Good Morning :
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Dec 03, 2012 | Net10 ZTE Merit Z990G Prepaid Cell Phone
Multiple texts sending when i only send them once!
it could be because you didnt have enough service to send them wit
Feb 18, 2010 | Cell Phones
My Nokia e51 wont send txt msg's, it used to be
there is a service center number in your message setting. if it is edited your messages wont go . correct service center can be taken from your service provider. if that is right the reset your phone once it will start working fine.
Aug 27, 2009 | Nokia E51 Smartphone
I am unable to send pictures from my motorola razr v3 black,text messages are o.k. I am using my virgin sim card from my old sony. Does my v3 have to be registered with virgin to send pictures? Please any...
Hi , The settings for this function are stored on the phone via txt message from your service provider (virgin).When you use your sim in a different phone all you do is request settings to be resent and install from the options that come with the message , check the phones/sim stored numbers for virgin to txt "get settings" , or check online for the number to request
Mar 24, 2009 | Motorola Mobility RAZR V3
Can't send/receive picture messages on Motorola Razr V3
This is simple u ask ur service provider for mms activation&receive settings then u send r receive any mms
Mar 13, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Everytime i send a txt message on my razr slide it says message failed right away then when i check the message status it says its a network problem, any ideas whats goin on there?
Hi!
Contact your service provider and ask them for message center number and enter that number under message settings. You will then be able to send the messages.
Please ask for further clarifications.
Please rate this solution as fixya if found useful.
Thanks
Rylee
Mar 04, 2009 | Motorola Mobility RAZR V3
I can't send any message or recive
How can I use the messaging features on my Motorola phone? space.gif space.gif answer.gif To send a text message:
  • Enter your Message menu
  • Scroll to Create Message and Select
  • In the To: field, either enter a telephone number**, e-mail address**, or Browse your Phonebook, Received or Dialed Calls list.
  • Enter your message in the MSG: field
  • Select done when you have completed the To: and MSG: fields
  • Confirm that you would like to send the message now
Please note that text messaging is a service provided by your cellular service provider and you must subscribe to this service to have the capability to send text messages. Certain carriers may require alternate instructions.
**Please contact your carrier for further information on these services, and to ensure they support sending to both a telephone number and/or e-mail address.
To send a text message - Select Menu, Messages, Create Message, and then New TXT Msg
<a href=""http://motorola.custhelp.com/cgi-bin/motorola.cfg/php/enduser/std_adp.php?p_sid=Id42qGph&p_lva=4061&p_faqid=4064"" target=""_self"">To send a multimedia message -Select M, Messages, Create Message, and then New PIX Msg
To Insert Objects In Text Message while composing a text message - Select Menu, and then Insert
To use MMS Template open an MMS template with preloaded media - Select M, Messages, Create Message, and then PIX Templates
To read a new text or multimedia message that you have received - Press Read (Right Soft Key).
To Store Message Objects - Go to a multimedia message slide, or highlight an object in a letterand select Menu, and then Store
To send or create a quick note message - Select Menu, Messages, and then Quick Notes
To view sent messages - Select Menu, Messages, and then Outbox
To read received messages - Select Menu, Messages, and then Inbox
Tip: Press Menu to perform various operations on the message.
To view messages saved in drafts folder - Select Menu, Messages, and then Drafts
To delete all messages or only messages from the Outbox or drafts folder: Select Menu,; Messages, and then Cleanup Messages
Oct 22, 2008 | Motorola Mobility RAZR V3
Helpppp!!
ok first make sure your phone has enough credit or your post paid bill is paid.If thats ok,go in message on your phone,then go in message settings,and make sure the service center number is correct.
Aug 01, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Txt messages
Error message 38 means there was some type of problem with the number to which you were texting. When sending a text message, make sure you are sending the message to a ten-digit mobile number (assuming you are in the US). If you're sending a text message to an entry you've saved to your address book, make sure that you stored the number with area code in your address book.
If all of that checks out, or if you've had no problems texting to this exact number before, you will want to place a call to customer service with your wireless service provider. They can look at message logs within their network to see what happened and why the attempt failed.
good luck
c.j.
Mar 26, 2008 | Motorola Mobility RAZR V3x Cellular Phone
No pic/video txt can be rec'd or sent out
try master resetting the phone and master clearing it , if that does not work then call you mobile service provider for them to assist you
Sep 28, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Mobility RAZR V3m Cellular Phone Logo
76 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
Lawrence Oravetz
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
