Question about Toshiba 46H84 46" Rear Projection HDTV-Ready Television
Toshiba 46H84 tv turned off light blinking
My tv just turned off and the front light started blinking, so i unplugged it and plugged it again it tried to come on, but the screen it turned red and turned off again.
i can hear some clicking noises in the back before it turns off.
  • 3 more comments
  • Anonymous Jan 29, 2008
    mine just did the same thing, tv just turned off red power light blinks but nothing else.........????
  • Anonymous Aug 25, 2008
    I have the same problem. A $1400 3 yr old TV shouldn't have these power suply problems.
  • one_eye_mate Sep 16, 2008
    i have the same problem but the screen is blue and sounds like a relay comes on when is sounds like the relay shuts off the screen goes blank and the red light flashes next to the power button
  • mgIII123 Sep 17, 2008
    same problem tv has blue screen turns off and has red blinking ligh tnext to power button
  • aristia Sep 19, 2008
    hi-
    my tv turns on then shuts off after a few seconds then the red light blinks. it's football season for crying out loud! just wondering if there is a simple solution. don't want to unhook everything and take it to a shop for god knows how much. its only three or maybe four years old!
    Problem Solver:
Sounds like a problem w/ the red tube.
Posted on Jan 07, 2008
Power supply has gone/
Posted on Jan 03, 2008
When i turn my toshiba tv model #46h84 the green bulb lights up the screen but then shuts off and there is no picture! please help me out!!!
I have the same exact problem...for a few weeks the TV would turn off and the red power light would blink. Then the other day I started having exactly the problem you describe...green screen for a few seconds and then total shutdown.
Feb 08, 2011 | Toshiba 46H84 46" Rear Projection...
Sirs: We were just changing channels and the
THE projection bulb is blown if no sound tv probably broken
Jul 31, 2009 | Toshiba 46H84 46" Rear Projection...
TV turns off and power light blinks unpluged andd still does it.
Likely to be the STK convergence chips causing a protection circuit to switch the TV off. Have you got any onscreen convergence problems (i.e, colour fringes)?
May 27, 2009 | Toshiba 42H81 42" Rear Projection...
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Sep 17, 2008 | Toshiba 46H84 46" Rear Projection...
Toshiba 46H84 turning off by itself AND all BLUE screen with Black Dot in Center
Try to replug everything in the TV. Before you turn it on. make sure all plugs in the TV to the wall is plug in tight. When you turn your TV on hold the power button down to see if it resets
Feb 28, 2017 | Toshiba 46H84 46" Rear Projection...
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
TURNS OFF BY ITSELF
my tv starts turning a red color and then turns off by itsself then i have to unplug it to turn it back on every 5 mintues or so.
Nov 14, 2007 | Toshiba 46H84 46" Rear Projection...
46h84 toshiba rear projection tv
possible yoke fault or deflection /ask for an estimate before the repiars are done.might cost you a service call.
Aug 05, 2007 | Toshiba 46H84 46" Rear Projection...
Toshiba 46H84 46" Rear Projection HDTV-Ready Television Logo
431 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
