Question about Lexmark Z53 Color InkJet Printer
HP Z53 It appears a part has fallen out of my printer. It appears to be a tray on which an ink cartridge would rest. It apparently is a nessesary part for the printer to function because since this happened the printer doesn't work. When I trun it on the ink cartridge holder moves violently and with a thud to to the left, then repeats this action to the right and stops. Then, it turns itself off. The power light then blinks twice and pauses. And repeats itself indefinitely. It does this with or without the cartridges in place. Anybody have any ideas on what happened here ? Thanks for you consideration. MarshallWhite@aol.com
Bogdan
  • 198 Answers
SOURCE: Lemark Z52 Inkjet
Hello, First of all, let's start with some simple questions. 1 Was the cartridge ever refilled or is it in the original state? 2 How exactly did this occured? I'm asking this because most printers have a limited space inside them for the cartridge to move around when printing. If they don't fit exactly as they should, they will most likely hit something in their movement when printing. If your cartridge was refilled maybe the person who did that didn't attached the cartridge top part properly and now it moved out of position and hits the inner top of the cartridge housing. Please provide me first with these informations so I can better assist you.
Posted on Sep 09, 2007
IB4G2008
  • 3587 Answers
SOURCE: Paper sensor, I think
check the cable first..and do a test page, if you can without the printer connected to anything.
then, if that all works, we can look elsewhere, no?
Posted on Mar 11, 2008
Ajkill
  • 2035 Answers
SOURCE: lexmark 4350
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:479:0:0&framed=&docid=ENUS25494&relevance=1
Posted on Apr 13, 2008
  • 6 Answers
SOURCE: Broken the bottom print cartridge holder - blueish gray
The part has been broken in my printer for over a year now. I hold the cartridge in with a rubber band.
Posted on Apr 14, 2009
Roop1980
  • 228 Answers
SOURCE: ink cartridges make a slamming sound from left to right and wont print
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test. If it slams to the left again, the strip is not yet set correctly.
If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
Posted on May 28, 2009
HP Photosmart 8250 printer appears to be dumping ink on the right side. it is on the silver tray when you open the compartment under the lid. I have cleaned it up, tried a different cartridge with the...
I've got a somewhat similar problem with an 8250 which doesn't print even with $60 of new cartridges. Something about air in the lines which with this particular model may require 'startup cartridges' which are reportedly shipped with a new printer. HP's solutions haven't been at all helpful; my solution would be to trash this printer and buy another brand.
Sep 16, 2013 | HP Photosmart 8250 InkJet Printer
I have an HP Photosmart C5180.ink appears to be missing or damage
Hi there
Most times it just need a good clean ,take out and clean the brass conextions.
All the best Pineworks
Apr 27, 2010 | HP Photosmart C5180 All-In-One InkJet...
Disintigrating belt that moves the tray of ink cartridges on prin
Yes, it's definitely cheaper to buy a new printer.
A new printer will come with a CD-ROM, containing the necessary instructions and software for use with the new printer.
Before you connect the new printer, insert the CD-ROM, and it should "guide" you through the whole "install" process.
Dec 08, 2009 | HP DeskJet 895cse InkJet Printer
Black ink won't appear on page. full ink
try taking the paper tray out and slamming the tray back in -- not to kill it but to jar it. Or maybe smacking the front of the machine. This will open the bar flap. Sounds kooky but try it.
Sep 23, 2009 | HP Color LaserJet 3500 Printer
HP Photosmart 3110 All in One says ink cartdriges missing
Follow the instructions in this link.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00409514&prodTypeId=18972&prodSeriesId=3380537
May 18, 2009 | HP OfficeJet J4580 All-In-One Laser...
All three lights flashing, tray for cartridges inside housing
You have a faulty carriage mechinism in your printer. you can try putting a drop of sewing maching oil on the carriage rail (the silver bar inside the printer that the head goes back and forth across), but if this fails, your unit is not repairable as hp do not supply parts for their inkjet range of printers.
gremlin 11
Dec 11, 2008 | HP DeskJet 722c InkJet Printer
Ink cartridge problem! The following ink cartridges appear to be missing or damaged.
hi!!!!
try to clean the nozzle of your cartridge with the alcohol
or solvent used cotton
or replace the cartridge
try to email me ronaldsuboc@gmail.com
Sep 18, 2008 | HP Photosmart C7280 Printer
Lexmark Z53 Color Jetprinter
plese clean your printer drum unite clean wast ink
Apr 25, 2008 | Lexmark Z53 Color InkJet Printer
Ink
Normally when you install the print software you install HP Director or solution centre software that has a estimated ink staus monitor..from user manual
Check the estimated ink levels You can easily check the ink supply level to determine how soon you might need to replace a print cartridge. The ink supply level shows an estimate of the amount of ink remaining in the print cartridges. Tip You can also print a self-test report to see if your print cartridges might need to be replaced. For more information, see Print a self-test report. To check the ink levels from the HP Director (Windows) 1. In the HP Director (or HP Solution Center), click Settings, point to Print Settings, and then click Printer Toolbox. Note You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device. 2. Click the Estimated Ink Level tab. The estimated ink levels for the print cartridges appear. To check the ink levels from the HP Image Zone software (Mac) 1. In the HP Director (OS 9) or HP Image Zone (OS X), choose Settings, and then choose Maintain Printer. 2. If the Select Printer dialog box appears, select your HP All-in-One, and then click Utilities. 3. From the pop-up menu, choose Ink Level. The estimated ink levels for the print cartridges appear.
Print a self-test report If you are experiencing problems with printing, print a self-test report before you replace the print cartridges. This report provides useful information on several aspects of your device, including your print cartridges.
Load letter, A4, or legal unused plain white paper into the paper tray.
Press and hold the Cancel / Resume button and then press the Start Copy Color button
The HP All-in-One prints a self-test report, which might indicate the source of the printing problem.
Jan 12, 2008 | HP PSC 1510 All-In-One InkJet Printer
Lexmark Z53 Color InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
