Question about HP PSC 1410 All-In-One InkJet Printer
Appears to be a roller crease on the paper
All pages print or copy, come out with a roller crease. But the position of the crease doesn't seem to line up where there is any roller. Also the toner smudges in the same crease.
  • Anonymous Mar 19, 2014
    paper is creasing and or ripping as copy is being made. the machine is also getting hot rather quickly.
I want the installation cd fo my printer HP PSC 1410
Posted on Jan 07, 2008
Crease in paper when printing
Your information is a bit limited but we'll try anyway.
If the crease is a corner fold or a pressure line down the page, it will often be caused by something in the paper feed path close to the main drive bar in an inkjet or near the fuser in a laser printer. Have a look at the leading edge of the paper as it exits the printer for a nick or mark that may give a clue where to start looking. If there is a fold or crumple line down the length of the page, look at the paper pick up mechanism in an inkjet (usually the paper tray is a good start) or if it is a laser printer you should remove the fuser and check the fuser sleeve and pressure rollers. If you could let me know what the machine is and where the crease is I may be able to give better advice.
Jul 09, 2015 | Office Equipment & Supplies
Crease in page when printing cannon image runner 1310
A crease is usually caused by two issues. 1 ) paper is hitting something on the way to the fuser causing a skew. This type of problem would be repeatable every page as well as causing the image to be off centre. The 2) reason is the more likely cause. A bearing on the lower (pressure roller) is beginning to seize. Causing paper not to feed straight through the fuser. This cause a wrinkle from from to back on the sheet of paper. This wrinkle although repeatable generally the wrinkle position up or down on the sheet. This gives the impression of something that is getting in the way of the sheet. If you can change your lower pressure bearings you should be ok again.
May 03, 2013 | Cannon Office Equipment & Supplies
Have an HP LJM9050 MFP printer. Getting almost constant jam in transfer roller and any successful prints have a crease. We were told by a tech that the issue is the paper we are using. We use Staples...
It is better to try with good brand printing paper as the lower thickness of the paper will only make the paper crinkle within the roller as it will BITE into the roller and be pulled into with different tension.
So test with another brand to confirm. If not the roller alignment must be checked.
Sep 03, 2011 | HP Office Equipment & Supplies
4215 all in one office yet. When making a copy
Sounds like you're having a problem with the automatic document feeder. The scanner is continuing to scan but the paper is not advancing as it should during the first part of the infeed. Check to see if something is inside retarding the path of the scanned document. Or it could be worn rollers in the ADF.
Jul 18, 2011 | HP Officejet 4215 All-in-One Color Photo...
When you print each page has a gray/black line running down the page from top to bottom about 2.5 inches from the edge of the paper. Sometimes it is darker and other times it is lighter. We have tried...
While the line is showing up on the output pages.
Stop printing and put paper in the manual feed tray (tray 1).
Start printing again. As a page gets pulled into the printer about 1/2 way open the top cover.
Pull out the toner and look at the page inside the printer. If it doesn't have the grey/black line, get the fuser replaced. It is defective.
Jun 09, 2011 | HP LaserJet 1300 Printer
Kyocera Mita FS-1000+ paper slip single page? 5 pages print ok
This is a known problem.
Kyocera pretends to produce very silent printers. Therefore certain sheet metal parts inside the printer have a small piece of sponge rubber at their endings.
Unfortunately over the years this sponge rubber gets sticky. The corresponding lever, that is covered at its end with sponge rubber, sticks too long to its initial position. This is the reason why a certain lever is moved too late by the electromagnet into the position where a certain pulley is released.
As a result printing and paper movement are no longer coordinated and the printout is too low on the sheet.
Solution: Get rid of the sponge rubber, clean the lever very well in order to avoid it from sticking in its initial position. As a result you will here a much harder metallic noise when the lever moves, but the printout should be o.k.
Apr 07, 2009 | Kyocera Mita FS 1000+N Laser Printer
Black lines on the right side of every copy
depending on what the lines look like it could be the charge roller or transfer roller.
A defect on the charge roll appears as black areas on the front of the test page, and as light gray areas on the test page.
A defect on the PC drum of the toner cartridge appears as white areas on a dark, full–coverage test print and as black areas on the "text only" test page.
I have also seen a line with a 'ridge' on the paper. This will appear almost like an embossed line. This was caused by the fuser roller being scored by debris.
Jan 12, 2009 | Dell 1710 Laser Printer
Printed paper is creased
First thing to check is try it with a fresh unopened ream of quality paper, paper with too much moisture content, drys out and goes wavy when it runs threw the fuser roller at rear (180 deg), otherwise it will be the fuser rollers themselves causing your problem, which means that you need to replace fuser assy
Dec 05, 2007 | Samsung CLP 300 Laser Printer
HP PSC 1410 All-In-One InkJet Printer Logo
376 people viewed this question
Ben Johnson
