Question about Vacuums
Hoover Model S3281, disassembly instructions
Hi, the cord retractor reel in my Hoover Dimension 1000 (Model S3281) needs to be freed up. How does the rear plate on this vacuum come off so I can gain access to the cord reel?
  • Anonymous Mar 17, 2014
    replace retractor cord on Meile white star vacuum
GET TO THE REEL AS FOLLOWS:
(BEFORE YOU START, BE SURE TO UNPLUG THE DIMENSION FROM THE OUTLET)
1). TURN VACUUM OVER AND USE A FLAT-BLADE SCREWDRIVER TO WEDGE/SLIDE THE WHEELS OFF (PUT THE SCREWDRIVER BLADE BETWEEN THE LITTLE BLACK WHEEL BRACKET PIECE AND THE GREY CHASSIS OF THE VACUUM AND SLIDE/WIGGLE THE WHEELS OFF);
2). THE 2 DEEP HOLES AT THE TOP OF EACH WHEEL RECESS LEAD TO 1-1/2" LONG PHILLIPS SCREWS >> UNSCREW THEM;
3). AFTER REMOVING ALL 4 SCREWS, YOU SHOULD BE ABLE TO EASILY LIFT OFF THE TOP OF THE REEL/MOTOR COMPARTMENT.
4). CAREFULLY LIFT AND ROTATE THE CONTROL PANEL TO THE SIDE.
5). THE REEL IS NOW IN PLAIN SIGHT.
6). I’M STILL TRYING TO FIGURE-OUT HOW TO SAFELY ACCESS THE GUTS OF THE REEL MYSELF. I HAVE A PROBLEM WITH INTERMITTENT VACUUM POWER AND ALSO WITH WEAK CORD RETRACTION.
ANYWAY, GOOD LUCK TO YOU !!!
Posted on Apr 01, 2009
That solved my Hoover Dimension 1000 Vacuum cleaner problem with the tangled cord issue. When I fixed that problem another arose now the cord will automatically rewind automatically without my intervention. A few parts fell off trying to figure out which one prevents the cord from rewinding into the machine automatically.
Posted on Jul 23, 2009
    President:
  • 1,673 Answers
Alot of these Hoovers has a panel on the top, near the back that has some screws to take out, then that panel comes off. The motor and reel cord are under that cover.
Posted on Jan 22, 2008
Simplicity mode l8526L pull cord wont retract
The retractor has failed. You will have to disassemble the machine, find the retractor and repair/replace it.
Jul 12, 2016 | Simplicity Vacuums
Hoover dimension 1000
There are a few screws on the bottom of your hoover, remove them using a suitable unarmed and then pulling firmly upward.
Jul 04, 2013 | Hoover S1361 Bagged Canister Vacuum
I have a Miele Solaris that is having an intermittent power problem. The power will not turn on unless I push the cord winder button at the same time as the power button. I have disassembled the vacuum and...
These type of cord retractors have a set of contacts which sometimes get corroded or bent. Or maybe the reel has become wobbly.
As the cord reel moves, these contacts should have enough pressure stay in contact with the tracks on the reel at all times.
You sound like a handy person, so you would have to take the assembly right out of the machine and perhaps be able to correct the situation.
Some of these contacts are easily accessible, and others not so easily.
While you have the old assembly out anyway, you also might be able to buy a new one to replace it.
Without a close look it's hard to guess what to advise you.
Maybe a vac repair shop could throw in an tune up as well?
Check the motor brushes and so on?
Jun 17, 2011 | Vacuums
VACUUM - 1. How to open up a Wertheim 5030 to get to the cord retractor 2. How to fix the retractor so that it retracts the cord.
Hi to do this you will have to somehow find a service manual, this will give detailed instructions on why and how. I have searched for one however i was unable to find any. Perhaps a direct plea to the manufacturer may help?
In any event, usually the is NO "Fixing" of the retractor, most often, the mount at the rear attachment of the coiled spring, brakes and this stops it retracting.
The fix is to replace the entire recoiler assembly. This is pretty simple job, if one can obtain the parts.
However my professional advise is to take it to a vacuum repair shop, (NB: Only take it to a repair shop that deals in YOUR brand) and ask for a "Quote" for the repair, I am sure it will be modest indeed. You see this is just such a common thing that they fix all the time.
Mar 26, 2011 | Vacuums
Cord will not retract?
This is caused by a broken retractor reel spring, you will need to replace the retractor.
Jan 28, 2011 | Electrolux Epic 6500 Vacuum
Cord will not remain OUT..keeps slip-sliding back in
The return is stuck on your cord retractor. Take the machine apart untill you can see the retractor, then there is a button or wire that retracts the cord. If it is stuck in the down possition simply reset it, if it is broke you must replace the complete cord retractor.
Apr 11, 2009 | Hoover S3755 WindTunnel Bagless Canister...
Electrolux LE, cord retractor not working
This happens when the spring inside the cord reel fails. The reel can't be fixed, but can be replaced. A Google search for Electrolux parts turned up several sources. Here's a link to one company I have dealt with in the past:
http://www.totalvac.com/accessory/parts/EXR-3075ES.html
Replacement isn't too difficult if you're comfortable with hand tools and have some patience. Hope this helps and good luck on the repair!
Nov 22, 2008 | Electrolux Vacuums
Vacuums Logo
1,099 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
