Question about Kenmore 22932 Top Load Washer
Kenmore Elite Model 23032101 Top Half of Agitator Not Working
How do i remove the top half of the agitator to fix this problem?
duby1990
  • 370 Answers
SOURCE: Washing machine agitator upper half not working I have a Kenmore Elite
Pull the fabric softener cap off, next pull the top cap off the agitator. Then remove the 7/16 bolt in the center of the agitator. Then you can remove the top part of the agitator.
Posted on Nov 20, 2008
WRMtech
  • 70 Answers
SOURCE: top half of agitator turns free (does not agitate)
You will need a set of agitator dogs. Pull off your agitator cap and look under it, you will see 4(four)small tabs that catch and release the top 1/2 of the agitator.
Good Luck!
Posted on Feb 26, 2009
jsrock516
  • 5911 Answers
SOURCE: How to remove the agitator from a top loading
The agitator on a Kenmore top loader can easily be removed by performing the following steps:
1. Remove the agitator center cap (or fabric softener dispener) by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4. Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make reassembly much easier.
Is there a reason you are removing the agitator? If you have questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Jul 09, 2009
  • 1937 Answers
SOURCE: top-load agitator removal
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136
Some versions of top load Kenmore washers use a two piece agitator.
1. Remove the fabric softener dispenser.
2. Using a short screwdriver, pry off the top cap of the upper agitator.
3. You may see a 1/2" square drive nut. Remove the nut and pull the top agitator off. Underneath it are the agitator dogs.
4. You may see another bolt that holds the lower agitator onto the main transmission agitator shaft. Remove the bolt and pull the lower agitator off.
Posted on Oct 20, 2009
  • 1937 Answers
SOURCE: dual action kenmore 70 series washer need to remove agitator
It sounds as if your "Agitator Dogs" are damaged or broken. These are plastic pieces that allow the top agitator to turn only one way.
Please see the following for how to access and replace them if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=39649e541343127154c647348d1156d9
Basically,
2. Using a short flat blade screwdriver, remove the cap.
3. You may see a 1/2" square plastic nut.
I've used a 1/2" extension for a socket set to remove the nut.
4. Pull the top agitator off and turn it over carefully.
You should see the agitator dogs (per the illustrations).
Replace them if necessary and re-mount the agitator, tighten the bolt carefully, put the cap and fabric softener dispenser back on and the top part of the agitator should only turn one way.
Posted on Nov 06, 2009
Kenmore elite oasis washer model 110
the top half comes off --- the dog ears that ratchet the top are gone. There is a replacement kit to fix it --- About $30 You need to pull off the top of the agitator and use a long driver and socket to take off the nut you can see inside the unit. It is an easy fix. Just go to the appliance parts store and get the replacement part. You can wash your clothes without it working but it has to be a small load until you fix it
Jan 08, 2014 | Washing Machines
Top half of agitator is not moving, while bottom half operates normally
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Sep 07, 2010 | Washing Machines
Why wont the top portion of my agitator spin? It appears there are plastic gears within the top portion of the agitator. Can these be inexpensively replaced?
Whirlpool, Roper, an Kenmore are the only brands with rebuild able agitators. Any other brand will need a replacement agitator. The parts are about 6 to 8 dollars.
Here are some instructions I recently posted for someone else with a similar problem on an older whirlpool washer. If you need more specific instructions or the model you have is different let me know and I can look up the parts breakdown and give you step by step repair instructions.
Does the lower half of the agitator still operate normally? (Back and forth) Can you spin the top half (spiraled part) of the agitator in both directions with out the lower half moving? If so then you have a worn set of agitator "dogs" they are little plastic ears located in the upper half of the agitator and catch the notched inner section of the agitator to make the top action work like a corkscrew, slipping one way and driving the other as the lower half goes back and forth.
To get at these parts you will need to remove the agitator, Remove fabric softener dispenser or cap on top, and look down inside tho opening.
You will need to remove the plastic cover inside that has two ears sticking up, pull on one side or the other and it should pop out, there will be a rubber seal around it so it will be a little difficult to remove.
Now you will have access to the bolt that holds the entire agitator in the machine. The agitator dogs are located right on the outer edge of the center cup that the bolt goes through. To access them you will want to separate the two halves of the agitator and flip the top half upside down while holding your hand inside it to catch the cup with the dogs in it. Part number 80040, for the dogs.
Good luck to You!!
Jun 30, 2010 | Washing Machines
How do I replace the dogs in a Kenmore Elite washer?
With a flat blade screwdriver or putty knife, remove the top cover from the agitator. Use pliers to pull out the inside plastic cover.Take a 7/16 socket on a extension and remove the nut .Pull the agitator out. It should separate. If it does not separate,stand on the lower half and forcefully pull up on the upper half.Remove the agitator dogs and spline gear from the upper agitator. Replace the dogs. Re-assemble the agitator. Wash clothes.
Jul 14, 2009 | Kenmore 15.5 in. Pedestal
Dog Agit replacement on a Kenmore washing machine?
Take the top cap off the agitator.
Remove the plastic cover inside.(use pliers to pull it off).
Remove the bolt.
Pull the top half of the agitator off.
Replace the dogs.
Re-install the agitator.
Mar 08, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Dual Agitator not working
If the upper portion of the agitator is not working, this is commonly caused by worn agitator dogs. The following link explains:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
Yes...there is such a thing. These small plastic pieces have been the source of many trouble calls and only cost a few dollars to replace if you know how to do it. Replacements can be ordered on line at searspartsdirect.com, appliancepartspros.com, or repairclinic.com. Use your model number for the search criteria and look under the "Agitator Parts" section. The link also give instructions on how to remove the agitator. This is a very simple repair, that only costs a few dollars. If you wish not to order on
line, use the part number provided by the Sears website and go to your nearest appliance parts retailer. This is a common part they will have in their inventory. If you require further assistance, please let me know. I hope this helps you.
Jan 09, 2009 | Kenmore 24032\24036 Top Load Washer
Removing Agitator from Kenmore Model 110 Top Loader
How to replace Whirlpool/Kenmore washer
dual action agitator ratchet ‘dogs’, kit # 285770
Tools needed: Screwdriver, 3/8" drive ratchet wrench, 7/16" socket (older models), 3/8" drive to 1/2" adapter (newer models), long 3/8" drive extension, small amt liquid detergent
1) Pry the agitator cap off by inserting a screwdriver into the cap’s notch
2) Pull the inner cap (if present) off – most Whirlpool machines use this inner cap, with a handle, to gain access to the center bolt
3) Remove the bolt in the center of the agitator
(Earlier models used a 7/16" hex-head steel bolt)
(Recent models use a 1/2" square drive plastic nut – use a 3/8" X 1/2" ratchet adapter)
4) On older models, grasp the bottom portion of the agitator and pull the entire ***’y off.
(Recent models allow just the top portion’s removal to access these ‘dogs’)
5) Older models – place the agitator on the floor, and, standing carefully on the bottom portion, pull the top half off. Turn it over, and the dogs will be accessible for replacement.
6) Newer model dogs can be replaced once the ratchet ***’y is removed. There are several versions currently in use, but most can be replaced without removing the bottom agitator half. All‘4-dog’versions use the 285770 kit, regardless of the cam ***’y style. (Older agitators, rarely seen now, used a pair of 2 larger dogs, which are a different part number)
7) On older versions, be careful to align the two tabs when inserting the upper ***’y back onto the agitator bottom half. When these are aligned, they will friction-fit the two halves together, making it easier to reinstall the ***’y. Handle it only by the bottom half to prevent pulling the top half off when reinstalling.
8) Lightly lubricate the agitator cap’s rubber gasket using a bit of dishwasher detergent, and push it back into place. (On the Whirlpools with an inner cap, lube that cap’s o-ring too – makes it easier to snap into place)
9) Reach around and pat yourself on the back! You just saved at least $75.00!
Dec 31, 2008 | Kenmore Washing Machines
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Broken Washing Machine Agitator
probably just what is known as agitator dogs just worn ..with no brand or model i assume it's a whirpool or kenmore ..1st remove softner dispenser (without brand can't say how it would come off ..some twist off some just pull off ) if agitator has cap underneath pull it off in center of agitator should be a bolt 7/16 if kenmore/whirlpool..remove it pull up on top half ..whole thing may come out if so just pull up sharply on top part..center part of top half comes out dogs are on it( 4 )again i'm assuming kenmore/whirlpool whirpool part # 80040 replace them and reassemble ..if any other brand will probably have to replace entire agitator..good luck
Sep 11, 2008 | Washing Machines
The top half of the agitator (near the fabric softner comp) is skipping while it is in wash cycle
yes the top half seperates from the bottom half inside the top half are 4 little parts called dogs. the part number is 241341. replace the dogs to fix it
Nov 27, 2007 | Kenmore 22932 Top Load Washer
Kenmore 22932 Top Load Washer Logo
424 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
