Question about Toshiba Satellite A60 Notebook
Toshiba A60, Won't Load Windows XP.
I bought a used Toshiba A60 pro and tried installing Windows Xp using the Toshiba Restore Disk.
The Disk seems to work because the installation progress bar shows and completes, but after restarting the Notebook so that l go into the final installation in Windows the laptop just freezes.
This has been the same with several Hard-drives l have tried to use, thinking that it could be something wrong with my HDD.
Thanking you in advance..
  • chris2041 Jan 01, 2008
    The memory is on-board so l cannot remove it easily, l have run the Memtest86, for testing the memory and it did not come back with any errors.
    I don't know what ealse l can do..
  • 263 Answers
Did you try with diferent memory ram may be that is your problem because the memory can not prosses all the data to download windows
Posted on Jan 01, 2008
  • Jose Ramirez Jan 02, 2008
    you have to make sure the restore cd is in good conditions if that is ok you may bad motherboard i did have the same problem with mines and it was the motherboard one time i did install diferent operative system an did work for some months and no more until i change the motherboard
How to install windows xp in toshiba qosmio f30-112
If the Notebook cannot find the device driver it is looking for then use this restore disk for an easy solution.
This restore disk will only work for use with Toshiba Qosmio F30-112. This restore disk contains every driver for the Toshiba Qosmio F30-112.
Toshiba Qosmio F30-112 XP ... windows XP restore disk is a one stop solution. The Qosmio F30-112 drivers in ... Toshiba Qosmio F30-112 XP Notebook plug and play will install ...
TOTAL: $15.92
hope this helps
Sep 12, 2012 | Toshiba Qosmio F30-112 Laptop DC Car...
How to restore original windows on a toshiba satellite a105-s4184
I have toshiba laptop satalite with 2 operation windows 2000 and HP windows running thus slowing the system down consiradably. Idealy would like to delete the windows 2000 professinal. Please help
Sep 26, 2011 | Computers & Internet
Hi! I bought a Toshiba SA60 laptop through my friend from holland.The language in the windows xp program was in dutch.I reinstalled windows-xp in English language.Can I use the original product key/code of...
hello, the drivers can be downloaded from the same place which is toshiba website. Now I personally have used an english key to install a spanish version of windows xp. I dont know if this would be the case with your version.
Aug 25, 2010 | Toshiba Satellite A60 Notebook
I want to restore my a25-3072 laptop back to factory specs.
ok first things first I believe you mean "XP tablet edition" instead of "Desktop Management Interface"
  • A Tablet edition just means laptop version of and operating system. Laptops need different operating systems, than desktops, to function correctly.
Second even if you are using a Tablet edition of XP you can't use it from another computer.
  • When ever you use a restore disk specifically designed for another computer you will get the error message you described.
  • You will need to find the original restore disk for that laptop, or you will need to find a new Tablet version of Windows XP.
Once you install a new version you should stop getting that error message. But it has to be brand new. Please rate me I want to know if I was of any help.
May 09, 2009 | Toshiba Satellite A25-S3072 Notebook
That model Toshiba does not come with a recovery CD, does not have a restore partition, and does not allow you to creat a recovery disc when working normally, so unfortunatly you have 2 choices.
1. Call Toshiba and try to get them to mail you a recovery disk, if they have any they will likely charge you for the disk + shipping.
2. Reinstall windows manually using a clean install, you can use any OEM windows disk as long as it is the same version as your windows product key on the bottom of the laptop (i.e XP Home/XP PRO/ XP MCE/ or VISTA - all vista disks are basically the same and have all 3 versions on them)
Make sure you have backups of the drivers for your network adapter and other hardware before doing a clean install.
Jan 22, 2009 | Toshiba Satellite A205-S4617 Notebook
Removing partial install of 2nd os
You should be able to do a SYSTEM RESTORE to a point before the XP Pro installation.
Start the machine and start tapping the F8 key until the boot menu is displayed. Use the arrow keys to highlight SAFE MODE and press enter. If you are given a menu to choose which Windows to boot into, choose the Home edition. Windows will load with the minimum drivers. Your screen display will be 640 X 480 and the icons will be large. You will eventually see a window advising you that you are in safe mode, click OK or NO. Click NO. That should open The System Restore function. Choose to restore the system to an earlier date. A calendar with be displayed. The BOLD dates are the ones that you can restore to. Choose a date that was before the date you tried to install XP Pro. Follow the prompts and the restore process will run and reboot your computer. Following the reboot, the installation will complete and Windows will open.
If you have installed a service packs or updates after the restore date you will need to install them again.
Good Luck! and please let me know how this works out for you.
Jan 16, 2009 | Computers & Internet
Toshiba satellite pro a60 power problem
did u install already all the drivers for the A60???
then, update / flash the bios...|PSA60U
Dec 30, 2008 | Toshiba Satellite A60 Notebook
I dont have a restore disc for my Toshiba EA 60-155
Yes you can use XP and restore/reinstall your computer
Dec 08, 2008 | Toshiba Satellite A60 Notebook
My equium ea60-155 needs to be reformated ; can i use xp install
Loading XP back on isn't the problem, it will be the chipset drivers that you will need for your onboard graphics, sound etc... before you format and load XP back onto your laptop contact Toshiba for the chipset drivers for your laptop.
If XP is causing you problems, why no repair the verison you already have on there? If you put the XP disk in when given the choice to press enter to install or 'R' for repair. Press R. It will replace any corrupted files to your system with new ones.
I hope this helps.
Nov 11, 2008 | Toshiba Satellite A60 Notebook
Toshiba Satellite A60 Notebook Logo
125 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
