Question about Uniden Cordless Phone
Center toggle not working all directions TRU 9485-2
So I am a tech. Took apart phone. Confirmed circuit is fine. Yep it's the same problem you get with TV remotes. Repeated use of key has worn off the metal oxide on the rubber pad of key. Tried the old graphite trick, but that only works for awhile.
So how do I order new membrane?
Spinman
  • 2 more comments
  • spinman1949 Jan 11, 2008
    I did get a response from Uniden with a phone number to order parts. We shall see if I can actually order this part.
  • Anonymous Feb 07, 2008
    my unidem phone that ive only had for exactly one year i cant use some to the button specifically to check my caller id it doesnot respond and on one of the handset i cant scroll up or down!
  • Anonymous Mar 27, 2009
    same problem here, Uniden no longer sells internal parts for phones...Uniden customer service is horrible, I'll never by anither Uniden product. 10 cent part and now the phone is junk
  • Anonymous Mar 31, 2009
    i have the same problem ,the center key don't work, canot scroll up or down..
  • 3 Answers
I've taken a look at the uniden australia site and it does not offer to buy or order pieces. Mostly likely, they'll ask to send it to a 'specialist'.
Ebay is always an option, if you know the exact membrane your looking for. Or find a local specialist shop, it should be cheaper than sending it in.
Thats all I can offer. Hope it helps.
Posted on Jan 03, 2008
Tru9485
Check it on the below link:
http://www.manualowl.com/p/Uniden/TRU9485/Manual/23299
It has option for English and French version of the manual.
Select the appropriate one.
Sep 12, 2014 | Lands Phones
I'm looking for a replacement Despard switch that is in a 3 way circuit...but is not a normal 3 way switch. I took it apart and the little spring broke inside so it will not hold position. It seems like...
1) It sounds like you have a DPST 4-way switch being used as 3-way switch.
Look at screws terminals - DPST has 4 screw terminals.
I saw a post that said 4-way despard is no longer made, and couldn't find one either.
2) Next thing is to identify brand, for example Pass and Seymour (Legrand), and then contact that company directly.
http://www.legrand.us/Contact.aspx
Legrand despard switch page:
http://www.legrand.us/Search.aspx?q=Despard%20switch&r=0.07261252740809632
3) Aplus sells P&S 3-way despard switches
http://www.aplussupply.com/ps/switchdevice.htm
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 04, 2011 | Pass & Seymour Acd1cc Despard Single Pole...
How to eliminate calls you don't want
Add your phone number to the national "Do Not Call" list at www.donotcall.gov.
Also, your phone may just be missing the information it needs to decipher the data. Try getting a cheep caller ID unit and connect it to you phone line. See if it registers the phone numbers in question.
Jul 29, 2010 | Uniden 5.8GHz Expandable Cordless Phone...
How can I clear the previous registrations from the TRU 9485 base?
Use the following steps to reset the base to factory settings for all TRU models:
1. Disconnect the power from the base
2. hold down the following three (3) keys: [dnd] + [middle soft key] + [*]
3. While holding down the keys, plug in the base (hold the keys down until you hear a long beep).
According to Uniden Tech support, this is supposedly all it takes to reset the phone.
Aug 12, 2009 | Uniden TCX905 Cordless Accessory Handset...
UNIDEN cordless charger for india
UNIDEN DOES NOT SUPPORT SERVICE IN INDIA, TRU 9466/TRU9485 WILL ONLY WORK IN THE US AND CANADA. USING ANOTHER CHARGER COULD DAMAGE THE BASE.
Feb 16, 2009 | Uniden 2.4GHz Handset
L6 phone
Hi!
My phone also fell into a bucket full of water. I just gave the phone to the service center for repair and it's now absolutely fine.
I would suggest you to do the same. Also, don't try to switch on the phone as it may lead to short circuit in your phone.
Thank You
Oct 04, 2008 | Motorola Mobility L6 Cellular Phone
Cordless phone keypad problem
I too have similiar problem with Uniden phone. In my case it is only the center toggle. I indeed took the phone apart and this problem relates to the metal oxide wearing off the rubber keys that make contact with the exposed circuit lines. This same problem is common with TV remotes. Sometimes you can take apart device and find that cleaning the circuit with rubber eraser can help the problem. You can clean the rubber contacts, but be delicate as you do not want to remove the coating on the key. As far as taking phone apart? Well it helps to be a tech with experience. Usually there is at least one screw or two to remove in the battery area. Then you gently pry the phone apart. Sometimes devices like this slide apart after the screws are removed. If you pry start at position nearest where screws join parts together and work your way up. You may dent the plastic a bit in process. Once you have two halves apart be careful in next steps. There will be numerous screws holding the phone to face. Also be careful of wires to speaker. They are usually hardwired. No plug. As you take apart take careful note of how wires are routed. Also be careful of charge contacts that slide into base of phone.
I could fix my phone if I could get the part, but I suspect Uniden will not sell me the part and ask me to send phone in.
Spinman
Nov 09, 2007 | Panasonic KX-TG2336-S Phone
My uniden tru 9485-2
My phone won't charge on the base unit. It does charge on the other smaller base.
Oct 19, 2007 | Uniden TRU9485 Cordless Phone
Tru 9485
Look in the handset menu under global setup, scroll to CIDCW, click OK, and set to on or off depending what you want.
had the same problem and was trying to get solve the menu in the base
May 06, 2007 | Uniden TRU9485 Cordless Phone
Uniden Cordless Phone Logo
88 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
