Question about Kenmore Elite 45986 Front Load Washer
F and h
We just hooked up the washer after 2 years of being in a garage and it started fine for a minute now it keeps flashing f and h. We checked the water and that is going in fine and it drains just fine. What could be the problem???
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. To open door, press "end of cycle", wait for 2 minutes or till you hear distinct click; do not force door.
Is your exit hose behind at 3 feet approx above ground level?
Rate me pl.....if helped.
Posted on Jan 02, 2008
  • prem mathew Jan 02, 2008
    Check the hose under the tub for blockage, sock or something....
I have a GE stackable GUD27GSSJWW - we are on the second one with the same issue. The washer will begin to fill (wash or rinse cycle) and then just stop and the lights start flashing.
It may not be the washer. Have you checked that the filter on the water inlet has not got partially blocked with rubbish from your water. This is a common reason for a fault like this. You will need to remove the washer, remove the water inlet hoses and then remove the inlet filters and clean them. I was given a very expensive washer a few years back that refused to work for the owner who bought a new one. After cleaning the filter, it continued to work for many years after that.
Dec 08, 2017 | GE Washing Machines
My pressure washer ran fine for 2 years now it shuts down every 2 or 3 minutes with or without water pressure resistance consistently
check or replace the water pressure regulator . clean / replace the end jet on the hose.
May 04, 2015 | Garden
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
What does error code 6P mean on an Amana washer model LW9203W2B
SH: Open thermistor. Unplug appliance and let rest for 15-30 minutes, then plug back in. If code continues, unplug appliance and call for service.
bP: Pressure switch error sensed. Washer will not operate when this error is displayed. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
rP: Water supply problem in spin cycle. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
LO: Lock Out mode. To activate, press START and STOP/OFF pads at the same time. To deactivate, repeat the procedure.
AU: Flashes when a factory preset cycle is put on hold. A normal function.
Clean Filter: Flashes when a cycle is selected as a reminder to clean the filter before starting a cycle for optimum drying results. Code clears when the door is closed and the START pad is pressed.
Dec 29, 2009 | Amana Washing Machines
My Kenmore Elite Oasis He Washer model #110.2706 will not fill with water. I have checked for blockage in the water lines and they are clean and clear. The washer is only two years old. It will hum like it...
Your fill valve needs replacing. Not too expensive to change. This is all based on the fact that you have checked both feeds to the washer hook up and that the shut off lever is fully open.
Jul 29, 2009 | Washing Machines
Pressure washer - no water flow
Is there a check valve on the hose inlet that is stuck, and won't let the water in???????
May 25, 2009 | Plumbing
Maytag washer
This is similar to a problem I had after my power suddenly went out while the washer was filling with water. When the power resumed the washer would no longer run water... all other systems (agitate, drain, spin) worked fine.
A 10 minute, $113 dollar service call revealed that there was a fuse inside the front upper left area that had blown. Remove the 2 screws at the bottom of the front panel to get access to the inside.
Check it out and replace it if necessary.
Jan 20, 2008 | Maytag LSE7806A Top Load Stacked...
Kenmore Elite 45986 Front Load Washer Logo
21 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
