Question about Canon PowerShot S3 IS Digital Camera
Battery problem The camera has worked great until a few weeks ago. Now with new batteries it shuts off and says it needs new batteries. Help!
  • 1 more comment
  • StacyJay Feb 21, 2008
    THe S5 IS was working perfect then said I needed batteries. I changed them and it still says I need new batteries.
  • AKSINHA Mar 18, 2008
    I purchased a new camera (canon S5 IS) on 1st of March. I am getting the same problem (even with brand new batteries it clicks couple of pictures and says - "Please change the batteries") right since begining. I am using ENELOOP Ni-MH rechargeable batteries, I also tried with other panasonic rechargeable batteries and got same results.
    I purchased it from a store in NJ and now am back in India. Please help.
    Thanks,
    Anand
  • Anonymous May 11, 2010
    had the very same problem. Returned it to CANON through the store I purchased it from. CANON said it was a problem with the shutter circuit and the cost to repair was going to be around $200.00!! I was and am not impressed. CANON would not deal with me direct unless I ship the camera direct to them. The retailer told me that I shouldn't pay to fix it and get a new camera. The camera cost me $600.00 and almost to the day the warranty expired, the batteries started draining! I will get a new camera and it won't be a CANON AND I will also return the camera direct to CANON telling them to fix it at no charge or replace. That way, at least, I'll have something I can sell.
My battery is broken
Posted on Apr 30, 2008
    Problem Solver:
  • 5 Answers
Had the same problem and I have changed over to disposable AA Lithium batteries and no problem since. (About 9 months now)
Posted on Jan 06, 2008
6ya staff
SOURCE:
My Vivitar Vivicam 5399 is refusing to turn on. It has worked perfectly up until a couple of weeks ago, when it started to turn off at random moments, usually soon after I had turned it on. Now, it doesn't...
Have you tried to see if the battery door is completely shut? This is usually the problem with many digital cameras with batteries. Clean the battery door and where the battery touches the metal of the door. Check to see if the door is completely flush with the camera body when you close it. I know for a fact that Vivitar cameras **** the juice out of batteries fairly quickly also. If you have the USB-cord provided with the camera, plug it into your computer and see if that holds a charge to your camera. If all else fails, call up Vivitar for further inquiry, your battery may be dead.
Mar 08, 2011 | Vivitar Vivacam 5399 Digital Camera
Battery won't charge
yes your battery are finish they can not hold the charge put new one on charge for 12 hrs not less
if there not fully charge it is your battery charger
defective....
hope that will help
Regards Alan
May 27, 2010 | Nikon Coolpix S560 Digital Camera
I have Kodak EasyShare P850 Digital Camera starting shut off and turn on and I could not understand "why?" it is happening because I changed batteries three times but does not resolve the problem. Please...
Try using a liquid contact cleaner. I read about this fix on another site, worked great for me.
A product called DeoxIT in the U.S. is what was suggested, I am in Canada and can't get that here so I picked up a product from a company called NexxTech. Just a liquid contact cleaner.
Take out the battery of the camera. Put a few small drops of the contact cleaner on the power button and let it drip down into the switch. Rotate the on/off switch back and forth 5-10 times, put the battery back in and Voila! Fixed!
No more random on/off irritations, camera works just like it did before the problem started a few weeks ago.
It worked great for me.
Good Luck!
Feb 26, 2009 | Kodak EasyShare P850 Digital Camera
Battery Charge error
Hey Lak_69,
One problem I know of is the battery for your camera should be model NP-20 not model NP-40. The NP-20 has 650mAh. I would exchange your new battery for the correct model battery, and see if this works. If this doesn't work I would try cleaning the battery terminals in the camera, and if that doesn't work go ahead and try a new charger.
Sincerely,
Allan
Go Ahead. Use Us.
May 13, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Camera battery is dead and was just bought a week ago
If the contacts have been cleaned in the battery chamber, check the lower contact post - it's spring loaded and often gets stuck and doesn't make good contact with the battery. A little WD40 usually will free it up. Your batteries are probably still good.
Oct 16, 2007 | Canon EOS-AE-1 35mm SLR Camera
Canon dc100 wont swich on
The camera seems to have these problems, and I think its because the power switch is on when the camers is being charged.
Sep 11, 2007 | Canon DC100 DVD Camcorder
Help w/ Sony DSC-S75
If this is your original battery, I believe that it is time to replace it. I had the same battery in my old S85, then my old 707. It finally wore out, with very similar symptoms. Go on Ebay and find an OEM replacement. Don't buy an aftermarket battery for your S75. Buy cheap, buy twice. That S75 is still a great digicam. Replace the battery and continue to enjoy it.
Sep 11, 2005 | Sony Cyber-Shot DSC-S75 Digital Camera
Battery Problem
It sounds like you either have a bad battery, battery charger or maybe the battery has dirty connections. Try another set of batteries and if it still happens let me know. BMW
Aug 31, 2005 | Canon PowerShot S100 Digital Camera
Canon PowerShot S3 IS Digital Camera Logo
108 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
