Question about LG DLG5988 Gas Dryer
Dryer won't spin
Our 2.5 year LG dryer will light up, but won't spin. It just makes a strange noise.
  • dandk Jan 04, 2008
    Thanks so much, problem solved on step one...a sock!
  • 3 Answers
Step 1- remove the face of the dryer, then remove the cover for the fan, check to see if object is blocking the fan, if object is there , remove object, if not go to step 2
step 2- check to see if the belt is broken, if the belt is broken replace the belt.
step 3 - remove the belt from the motor and turn the dryer on, if the motor doesn’t turn then you need to replace the motor.
Posted on Jan 01, 2008
Dlg2524w gas dryer has not ever dried a normal load like it should 2-3 hours a load. I looked at the belt and it has lots of tenichen but i have turn drum by hand to get it moveing?
Posted on May 17, 2008
Making a terrible noise
its cloged or the pad behind it is burned up
Jan 25, 2012 | LG DLEX7177 Dryer
LG Model DLEX7177RM makes a rumbling noise upon start up like a bad bearing or gear drive sound. Noise is cyclic at dryer spin speed. Dryer is only a couple years old. Are there any recalls, warranty...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 02, 2011 | LG Dryers
When drum spins it makes a metal on metal sound. Wife says the felt fell off. Drum was replaced about 2 years ago. Dryer bought in June of 2006.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 23, 2010 | LG DLE2514 Electric Dryer
Beko tumble dryer was making strange noise now no heat but still spinning
How old is your dryer? strage noise usually take place if the unit is old and worn out. I dont know of any washer or dryer doesn't make noise after years of using. The more you use the more ware and tear and noise come from the unit. Noise can be the belt loose or tumbler padding or flange, connected to a simple bushing is worn out, making the unit woobily noisy. No heat mean your heating elements probably burnt out need replacing which will cost 80-100 bucks. its fairly easy to replace once you remove the back cover. To find out what making that noise, the best thing to do is run the dryer with the back cover off by look and listhen and see what making that noise.
Jul 08, 2009 | Dryers
My LG washer/dryer started to make a strange noise this morning when I put a few towels in to tumble dry. I put it off immediately, and have just tried again (7.30pm). Still making strange noise, not...
Your michines are still under manofacture waranty call LG customer service at the address below.
LG Support Representative at (800) 243-0000
"Was this helpful?"
May 09, 2009 | Dryers
Did you resolve your dryer / noise?
heatman101
7687t
Apr 14, 2009 | LG DLG5932W Gas Dryer
LG dryer making unbelievable noise!!! Loud thumping noise. Took top off and drum is cracked seam where it is welded. This may be the cause of the noise.
Same problem here. Half of my LG appliances have failed within 2 years. Stay away from LG!!! They look pretty, though.
Feb 28, 2009 | LG DLG3788W Gas Dryer
LG DLG5988 Gas Dryer Logo
3,884 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
