Vcr help motor runs,tape turns,but pickups dont go far enough for head to play
  • suesadie Jan 02, 2008
    thanks ,plastic parts were worn out.tossed it.
  • 579 Answers
Sounds like the belts are slipping that drive the loading mechanism.
May have its gearing out of time but start by replacing the belts
Posted on Jan 02, 2008
How many motors are in the VCR section? example 1 motor for play, 1 motor for hi-speed rewind, 1 motor for hi-speed forward.
There are only 2 motors on the VCR sections.1 motor for the rewind backward and speed foward.1 motor for take in the VHS tape and eject the tape.The play button also used the same rewind backward and speed forward motor to push the film foward to the VCR play head head drums to play the tape.
Nov 24, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
JVC HR S8000U S-VHS VCR switch from stereo to mono during playing.
try to do a player head cleaning. just be careful doing this..
Aug 04, 2008 | Televison & Video
Tapes dont play etc
check the tip in my profile labled how to clean vcr heads.
Jun 11, 2009 | Emerson EWV601 S-VHS VCR
Model abv441 Picture flutters when playing vcr tape
Remove the casing of the unit. You will see a head where the tape runs across. Keeping it powered up, with tape in....There are three screws around the base of the head. With a small phillips adjust the head by turning the screws one by one. If you adjust out too far, the screws will come out completely. Take your time when adjusting. You will notice the picture change with the turning of the screws. The sound will change also. It takes very little adjusting to get it right. Play around with it and it will work in no time...Good Luck
Dec 16, 2008 | Allegro DVD Recorder VCR Combo ABR521
Tape stuck in VCR
could be that you're looking at a blown cartridge for that vcr tape. You may need to cut the tape, to extract that from the unit.
The play head would usually retract when the cartridge is removed, BUT could be compromised by some tape getting into the play head mechanism, and jamming.
be particularly careful with anything pointy or sharp, as the tape head does NOT like those objects near the read surface.
Mar 02, 2008 | Philips CCC132AT 13 in. TV/VCR Combo
VCR acting strange with audio and playing
It sounds like the audio control head is at fault.
If all prerecorded tapes (movies) play with audio level jumping up and down, is is likely that the audio head is dirty. The audio head in the VCR looks very similar to a head of an old audio cassette player.
First, try to clean the audio head by running a VHS head cleanning tape. The cleanning tape will usually clean the path of all tape mechanisms..
Good Luck
Feb 25, 2008 | Panasonic PV-V4523S VHS VCR
Sharp dv-rw260h vcr/dvd combi
The tape drive and head cylinder motors are having trouble synchronizing close enough to allow the manual tracking to work. Does it work on prerecorded tapes?
Could be:
Too much drag from the tensioning gizmo. (fixable)
Dirty tape path (fixable)
Damaged tape (does it have a crease along one edge?
dragging motor (not usually fixable)
Hope Ya Fix It!
Jan 17, 2008 | Televison & Video
Dont see Video only Audio
The video head may still be dirty even after using the cleaning tape. Take the top cover off. The video head will be the rotating drum about 1.5 inches diameter. Use a lint free cloth- dish towel etc, moistened with rubbing alcohol, and rotate the head a few turns. The actual pickup surfaces are at the bottom of this drum unit- you can see them- there will be at least two.
Anyway, if you look at your cloth, and see some black material, indeed the head was dirty. Let the head dry for several minutes, then do a trial play again. If your picture returns, then good- if not try cleaning a couple more times. Heads do eventually wear out, and other problems can also cause the no video.
Dec 23, 2007 | Quasar VHQ940 VHS VCR
Vcr not playing tapes, just ejects them
Not enough info. What is the product? Brand, model, how old?
May 13, 2007 | Philips MWD2205 DVD Player/VCR
Used a wet VHS cleaner and now my VCR doesn't work right. Help!!
The VHS cleaning cassette possibly deposited fiber in the heads in the drum. You may need to open the cabin and examine the heads and the mechanism for foreign matterial.
Feb 02, 2007 | Proscan PSVR72 VHS VCR
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
