Question about Sony Cyber-shot DSC-W55 Digital Camera
Dropped camera I dropped my camera very lightly now the lens are stuck. Is there any way to fix this without going to a repair? I just got this one week ago and the drop was so light. THe screen works it says Access though and then it says turn the camera on  & off i did this but it still doesn't help. But the menu screen & etc works. Please help, thanks!
  • Daniiela Jan 02, 2008
    I dropped my camera also and the lens is stuck.. it just tells me "access" and then "turn camera on then off" is there anything i can do do fix this??
  • catsmelody Jan 07, 2008
    I have the same problem with my camera!
    It happened just 2 days ago and I would like to know if I can fix it or I'd better start looking for a new one?!
Posted on Feb 03, 2008
Lens on my camera not working I want to fix the camera myself
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the
batteries. (obvious I know).
2. The
camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average
home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
May 30, 2010 | Olympus FE-20 Digital Camera
My lens is stuck and my camera won't turn on. I must have dropped it without realising, What can I do?!
1. Check the batteries. (obvious I know).
2. The camera has been dropped or knocked.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
Apr 21, 2010 | Fuji FinePix J12 Digital Camera
Lens error
Not really anything that can be done without taking it apart and fixing. Problem is then getting it back together!
I always suggest to friends that they buy a camera without the extending lens for just this reason.
You can try sending to Nikon or taking it to a repair shop. Most likely will be $100 or so to get it fixed. Or, they will tell you it's not worth fixing.
Aug 23, 2009 | Nikon Coolpix S210 Digital Camera
I dropped my camera while it was on and the lens was extended. And I dropped it right on the lens. And now when I turn the camra off, the lens does not go back inside the camera. Everything else is fine,...
if the cams making grinding or crunching noise the lens housing gears are broke. repair usually not very economical. about 80% the cost of cam when you bought it.
Jun 04, 2009 | Casio Exilim EX-Z57 Digital Camera
Lens stuck after dropping camera
Probably it can be fixed, but if the lens gears are too damaged the repair could be much expensive and you would prefer to buy a new one.
Take your camera to a qualified technician to check the price of a repair.
May 23, 2009 | Samsung Digimax S730 Digital Camera
Kodak camera dropped lens cockeyed stuck open
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 08, 2009 | Kodak EasyShare V1003 Digital Camera
Lens stuck. Wont extent all the way out of yhe case.
got dropped? ..basically this camera is dust now.... to fix barrel you can attempt to wedge pry or reshape ...but if dropped and tweaked lens barrel it is worth less than cost of repair...
if it is power issue only...try to reset ..go to cameras website to see if a resettign process is listed ..new firmware etc.. and hope that does it for you
Nov 08, 2008 | Cameras
Dropped my camera canon sd450
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Feb 17, 2008 | Canon IXUS V2 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
90 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
