Question about Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor
Monitor just stopped working
It was working perfect then in the middle of a game it just failed. No LED lights. No power. We checked the power cables and it works.
  • Anonymous Jan 03, 2008
    Same...was working when I went to bed...nothing at all when I awoke. Tried new power outlet, reboot of pc, and checked all connections...it appears to have died and it is barely 1 1/2 years old. Any hope?!
    Novelist:
  • 138 Answers
Ok I got the same problem. And this is the way how to examine where the problem is. You have to check that you can see the image on screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons (Power on both cpu and monitor), there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken. If you cannot see any icon on the screen. I would say that there are some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or dark spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Feb 07, 2008
Monitor wont turn on help
Hello there, first thing you should do is to check the power cable.You can do that by changing it with PC power supply cable .It is the same. If it turns to be OK then disconnect the VGA cable from monitor and then try to power monitor on.There should be an activity on front power LED. If the power LED is not showing any light at all, then do not go further the unit is not working .Else the power led should blink a couple of times then a window pop up scrolling on the lcd saying :" no video signal" so the unit is OK ..Hope this helps. Cheers.
Dec 05, 2013 | LG FLATRON L1919S-SF 19 inch LCD Monitor
Tip
I turn on my pc it work but no picture appear in the monitor
that mean one of three<br /> <br /> 1- see small square in the middle of the monitor mean data cable is damaged<br /> <br /> 2- monitor led didn't light mean power cable is damaged or monitor <br /> <br /> 3- vga socket in motherboard is damged <br /> <br /> best regards
on Mar 29, 2011 | Computers & Internet
The computer works fine...the screen does not show anything
best regards
Apr 04, 2011 | Computers & Internet
I have a gateway FDP2275W desktop monitor. the monitor will power up and display the Gateway logo in the middle of the screen, then goes black. The monitor is still getting a signal from the computer as...
This is a common problem with many LCD monitors. The
printed circuit board that provides a stable voltage for the monitor to operate
from starts to fail. The PCB can be replaced, when/if they are available, or repaired
in most cases at a much lower cost. for more information on this email me at
Sprint6@zoominternet.net
Dec 26, 2010 | Gateway FPD2275W LCD Monitor
My lap top was working fine yesterday , but when i went to turn it on today the startup said to use "run in safe mode " or others options similar to that , i chose one , & it still didn't...
Hi, sorry to hear you are having problems. 1. Start up your desktop as normal but as soon as it starts keep pressing the 'F8' key. 2. You will have a black background with white writing on and lots of options. 3. Use the up and down arrow keys and select last known good configuration, then press the enter key to select it. philswift_4.jpg
Your computer should start up. If you have a blank screen, do you hear the fans whirring and see lights on the front? If so then your computer works but is not sending s signal out to the monitor. Check all cables to make sure they are securely connected. If you still have no image. Swap your monitor for a friends one that you know works. This will test if it is your monitor that has failed. If you see an image on your friends you will need a new monitor or new monitor cable. If you do not see an image on your friends monitor and your PC has lights and fan whirring then you need to get a new graphics card. If you have no lights and no fan whirring it is outside the scope of this and we need some more information as it could be 1. Failed power supply 2. Failed memory 3. Blown motherboard 4. Failed processor
Please report back with answers to 1. Do you hear fans whirring? 2. Do you see a power light/led light up? (in example pic it is green) 3. Do you see the HDD (Hard Disk Drive) LED/light flash at all? philswift_5.jpg
Many thanks for your information
Phil
Dec 04, 2010 | Computers & Internet
I CAN SEE THE CPU FAN RUNNING, but i cannot see anything on my monitor,i mean my monitor is still in sleep mode
1) If the monitor has a removable monitor cable, and you have a Known to be good one to use for a test unit, try it. If it isn't removable, try another Known to be good working monitor.
2) If the monitor cable, and the monitor proves to be good, the next thing to suspect would be bad graphics.
Bad Integrated graphics on the motherboard, or if a graphics card is used, a bad graphics card.
3) I suspect it is a bad Power Supply. An issue that comes up so much, that I would skip 1 and 2 above, and check the Power Supply.
A) ALL of the LED lights, mumba_mwaba, use less than 1 Watt of power when in use.
B) EACH fan uses 2 to 3 Watts.
C) A typical Processor can use 51 to 125 Watts. Depends on what Processor it is.
(Older processors such as a Pentium II for example use less)
Enough power to light LED lights, and spin fans, (Or spin a few times and stop), but Not enough power to turn the Processor on.
This is why you may see LED lights lit, and fans spinning, but the computer isn't working.
The computer isn't sending a video signal to the monitor.
No Signal.
Do you have a KNOWN to be good, compatible Power Supply to use for a test unit?
May sound far fetched, but perhaps there is someone who has upgraded to a better computer, and has a computer they're not using, and you could borrow the Power Supply for a test unit.
Oct 29, 2010 | Computers & Internet
I have a hp a350 cpu.the problem is that the light of led has gone red,as before in working condition it was green. It can't start.the power to hardisk is also not coming.please tell a sollution.
As you say has become red and no power to the hard disk.
First check the power cable for any loose connections and check if it give power to the cpu and the fan placed on processor starts working as you start the power. If fan it starts and with in few seconds stops then your power supply/SMPS is weak or damage. So replace it for proper working of your computer. And if after power on all fines but red led on monitor and no power to hard disk Try to replace the hard disk power cables because they are not working because of it no operating system is detected and led of monitor is red. After replacing hard disk cables hard disk starts working and still no display or red led on monitor check the vga cable for loose connection or replace it.If you are using vga display from graphic card try to get display first from onboard vga slot.After it your problem will disappear and your pc run smooth and fine.
Aug 27, 2010 | HP Compaq d530 SFF PC Desktop
What does the red light mean next to the power button?
The red light next to the power button is usuall the hard drive led which should blink every time the hard drive is in use, there is normally a green or yellow light for the power that shoukld stay on constant when the computer is on.
Feb 09, 2010 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
Samsung samtron monitor does not work
Please check whether the power cable is properly inserted...
The power button of this model fails with time.You need 2 press it tightly and hold it till the LED is on....
try this...
Hope this helped...
Dec 21, 2009 | SAMTRON 55V 15" CRT Monitor
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor Logo
107 people viewed this question
Alun Cox
