The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 64902 Electric Dryer
How do I access the heating element in a Kenmore 70 series dryer? Model number is 110.66722694. ...
(More)
How do I access the heating element in a Kenmore 70 series dryer? Model number is 110.66722694. Thanks.
cycle switch works in cycle and turns off when complete. Problem is dryer starts when door is closed...
(More)
cycle switch works in cycle and turns off when complete. Problem is dryer starts when door is closed and not when the start button is pushed. Is the
Dryer starts on its own and then will not work when I need it to. it is crazy but suddenly the dryer...
(More)
Dryer starts on its own and then will not work when I need it to. it is crazy but suddenly the dryer will just start itself. I am not sure of the model
Kenmore electric dryer model 110-620-36100. When it works, it works fine, but has been acting...
(More)
Kenmore electric dryer model 110-620-36100. When it works, it works fine, but has been acting strangly (all intermittent) - beeping in mid-cycle, resetting for a new cycle unattended, periodically dead control panel, started on its own a couple of times, etc. Suspecting flakey microcomputer. Advice (besides an exorcist!?!), or experience with this problem? Thanks.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
