Question about Bosch HBL 745 Stainless Steel Electric Single Oven
Bosch Convection oven Coil
I changed the coil around the fan but none of the elements or the heat light come on.
Greg
  • GBosch Jan 17, 2008
    Yes, that was done. You have not given me any suggestions on why it's not heating though.
    Do you know what to do next?
    Greg
    Problem Solver:
  • 6 Answers
Does the fan come on?
Do the top and bottom elements come on?
If the fan comes on, but none of the other elements come on when selected, it might be that the thermostat switch needs to be reset.
By the thermostat connection at the back, there should be a switch - a small blue button, than might have popped out. Push it back in and see if it works...
It worked for me when I replaced my element, and last night when my over stopped giving heat, I had to open up the back and reset the button.
Hope it helps
Posted on Jan 24, 2008
    Problem Solver:
  • 14 Answers
I assume that you mean the circo therm element? If you do. Have you made sure that the wires that were connected are back on the same connections?
I believe, I'm doing this from memory, you should have two red/white wires they attach to one side of the element and the other wire to the other side connection.
Hope this helps
deep Diver
Posted on Jan 17, 2008
Trying to change element on westinghouse PAK806 stove with ceramic cooktop. cant figure how to lift hob.
Hi I have a Westinghouse PAK806. The oven works fine, heat and fan, but none of the plates will turn on.
Any ideas?
Jul 13, 2011 | Ovens
My omega europa oven is not heating up .grill fan
Sounds like a faulty fan oven element. To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit. Happy fixing!!
Mar 18, 2010 | Ovens
Main fan oven not heating
If the light and the fan are working then it is the heating element that has failed. You need to replace it.
Its not a difficult job but you have to take the back off the oven. The heating element is usually in a circular shape around the fan housing.
You have to disconnect the wires to the heater and remove the retaining screws, fit the new heater and reconnect. Remember to switch off the power before starting work
Jan 04, 2010 | Ovens
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
Smeg sp9000x.2 double oven - no heat from top oven
hi
the changes are if the fan is turning and light is on then the element around the fan will need replacing hope this helps
regards dan
Mar 19, 2009 | Ovens
I turn on my Technika electric oven (TB60F) and the fan will run but the oven will not heat. i thought it was the element and was told the element was for the grille, so therfore it has to of been the...
hi
behind the panel at back of oven is the fan and around that is a fan element the changes are this will be you problem . just remove panel and check weather the element has burnt out
regards
Fan but no heat
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please
Mar 14, 2009 | Smeg SE280X Stainless Steel Electric...
Smeg SNZ91MFX1 Fan heating not working
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Jan 01, 2008 | Smeg SE250XUK Stainless Steel Electric...
Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Dec 17, 2007 | Ovens
Bosch HBL 745 Stainless Steel Electric Single Oven Logo
409 people viewed this question
Top Bosch Ovens Experts
Oloyede Monsuru
michael_t919
Are you a Bosch Oven Expert? Answer questions, earn points and help others
