Question about Toshiba Tecra 8200 Notebook
Locating the battery gauge
I can't find gauge, which tells how much batter is left.Can you help?
    Sergeant:
  • 239 Answers
If you right click on your desktop open properties and go into you power setting and once there you should see a place in the lower hand of that window to have a antimated battery icon show up on your task bar, that should show the battery now and if your roll your pointer over the battery in the lower right hand side of your taskbar it will say how much power is left try that if it don't work let me know and I'll help some more, OK Thanks
Posted on Jan 01, 2008
6ya staff
SOURCE:
Battery icon at bottom right hand side of page dissapeared how to get it back so i can tell how much batter life i have left
When you plug in your computer it should give you the percent of how much power you have left in your battery.
Sep 28, 2015 | Toshiba Computers & Internet
After installing new battery how can i reset gas gauge to tell me how many miles i have left to emty
It should reset automatically after a few miles.You owners manual will have this info
Oct 21, 2012 | 2000 Lincoln Town Car
94 passatt wont hold charge battery ,aternator, starter all good
You may have dirt or acid on your batter causing it to drain quicker than usual. Cleaning your battery may help. Also you said the battery is good, it may not hurt to do an acidity test which you use this special gauge that you can pick up at any auto parts store. It looks like a see through plastic cage with a squeeze bulb on it. Remove the battery cell caps and place hose of gauge in acid and pump acid into the gauge. If you are under the recommended area that will cause your battery to not hold a charge. I hope this helps.
Mar 15, 2011 | 1994 Volkswagen Passat
My expedition keeps dying on me the battery dies once i get it started though it works fine its when i leave it parked over night there is a new alternator on it cause the old one went out and the battery...
I'd run it by Autozone if this was the batter that was in it when the alatnator went out it may have cause the batter to get a bad cell, they will check it for free, Most batters have a 3 to 5 yr. warrenty. DONT tell thim your alatnitor went out if the battery showes bad this will void the warrenty just simpley say my batter has a bad cell....of corse the place you bought the batter will test it as well befor they give you or pro-rate your old battery good luck
Dec 24, 2010 | Ford Expedition Cars & Trucks
I have to boost my jeep every morning before work and after work 10hrs later, my gauges tell me my batter level is at 14 when it starts but i need a boost everyday...grrr
It sounds like the alternator is doing its job but the battery is not. This could be due to either a faulty battery or you may have some accessory draining the battery without you realizing it. Stop in at your local autozone and they will check it for you for free.
Nov 19, 2010 | 1998 Jeep Grand Cherokee
89 chevy c1500 5.0l auto.....won't crank....solenoid just clicks
Sounds to me like you need to clean the battery post and the cables. Take off the batter cables and either take some sandpaper or a wire brush and clean the post and then do the same to the inside of the battery cables that comes in contact with the batter post.
Feb 01, 2009 | 1989 GMC C1500
Locating the batter AAA 1.2V in Malaysia
Actually in Malaysia 1.2V AAA batteries available in most gadget stores and even in supermarkets. You may also get on local eBay website. www.ebay.com.my
Jan 07, 2009 | Panasonic KX-TG1033S Cordless Phone
Nordic ware Belgiam Waffler maker
This is how I use the nordic ware...
1.Heat pan on medium heat on one side until temp gauge is in the middle. Dont turn pan at all when pre-heating
2. Open pan and coat bottom with a little butter.
3. Flip pan over and add butter to bottom side that has no butter.
4. Add batter quickly so butter doent burn. Add semi-thick batter in pan and only let batter run so there is about 1 inch of space left on the edge.(This space will fill with batter when you close the cover)
5. Temperature gauge should stay near the middle at all times.
6. Do not open the pan to check the batter waffle color or your crispy waffle will turn soft
7. Let waffle cook on first side until the steam that comes out from the side slows down to about half of the amount of steam that came out when battle was first put in. (Should be about 2 minutes)
8. Turn waffle pan over and DON’T open the pan.(you haven’t opened the pan once to look)
9. Let cook until steam reduces (Takes about 2 minutes)
10. Keep an eye on the temp gauge
11.Remember the first waffle always takes longer to cook than the second and third waffle.
12. If you have the urge to open the pan. Open the cover slowly. If it doesn’t open up easily then it is still rare and wait one minute to open. If you need to look, you should only open the pan after you turned it over. Once you open the pan, leave it open. If you close it the cripy top will turn soft.
13. Remember trial and error
Mar 16, 2008 | Nordic Ware 15040 Belgian Waffle Maker
Toshiba Tecra 8200 Notebook Logo
37 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
