Question about Zyxel P660HW-D1 Router
Zyxel Modem Router P660hw wont work on LAN
I have just bought a Zyxel Modem Router P660hw to run wired and wireless connection on 2 computers.
My router works on my computer upstairs on the wireless conection but wont work on desktop using wired connection? When I put my BT router back in it works fine (This is only a wired connection)
When I plug the Zyxel back in only wireless works.
Please can you help.
I am using Microsoft Vista system, if this makes a difference.
  • 5 more comments
  • Anonymous Jan 02, 2008
    Exactly the same thing is happening here, but with the same computer. If I plug in the G202 wireless adaptor, I get a connection, but I can't get the wired connection to work. This computer is running an older version of Windows, though.
  • jammy1969 Jan 02, 2008
    problem solved. Hurray!!!! Just make sure you have your user name and password for the blu screen youll be ok. It just needed to be configured.
    I started from the beginning using the instructions, make sure all firewalls, norton & all applications are shut down.
    Its all working fine at last.
  • Noah-Moralis Mar 31, 2008
    I have the opposite probem, I'm running off of an Ethernet cable right now, but I can't get the wireless to work?! I've lived without wireless for the meantime because i get too frustrated figuring the problem myself.
    Does anybody know if I missed anything when setting up wireless?
  • Kevin Toner Apr 30, 2008
    My zyxel P660hw will work my on my PC (LAN) but as soon as I connect with the wireless laptop, the laptop connexion works but I lose the PC connexion. The two will not work at the same time
  • Anonymous Mar 21, 2014
    zyxel router unable to connect to wifi error says connection timed out
  • Anonymous Mar 27, 2014
    Responding to Larry solution I do have a router I need conections solution ( wiring options have wireless modem apple router and the sonet zfe3116p )
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
Posted on Apr 30, 2008
En español pe
Posted on Aug 30, 2008
Key phrase
First, go to this site - 660HW Series ZyXEL - and download a manual for the ZyXEL P660HW-D1.
Quick start guide
Download Library
Next, hook up the router to your computer with a LAN cable. Open a browser and enter 192.168.1.1 into the url address window. The default login is 1234. Then configure the wireless settings - see pages 6 & 7 of the guide.
Feb 20, 2014 | Zyxel P660HW-D1 Router
No internet when adding switch between modem and router
The router controls and assigns IPs. Configuration goes from ISP modem to router to switch.
Mar 20, 2013 | Zyxel Communications Zyxel GS105B Desktop...
Zyxel P660HW-D1 Router. Which settings need to be changed to turn it into a repeater and connect with my main broadband router.
Can't use a router as a repeater in a wireless sense. You could set it to AP mode and run an ethernet cable from a lan port on your other router to the WAN/uplink port on the Zyxel. If it doesn't have AP mode then you could have it in gateway mode run have a different subnet on the Zyxel with DHCP.
Oct 29, 2011 | Zyxel P660HW-D1 Router
My Zyxel P-600 series modem is connected to my desk top. Can i get a wireless connection to my laptop?
Yes you should! Download a manual for your router and read how you start the wireless LAN. I think you login to your router by writing 192.168.1.1 in the URL window in a web browser. Password is 1234 as default. Be sure to encrypt the AP with WPA so that your neighbours dont use your internet conection.
Aug 25, 2010 | Zyxel P660HW-D1 Router
Ethernet to router connectivity issue
The correct way to do the connection is by plugging the Desktop to one of the Ethernet ports and any wireless device over the wireless network.
Dec 01, 2009 | Zyxel P660HW-D1 Router
There's a network key for my ZyXel P660HW-T1 modem when connecting through wireless, and i never set any network keys before, what could be the probleM?
See there might be network key set up on the wireless modem already, you will need to check what the network key is ?
For this you will need to access the set up interface of the modem/ router.
Is there any computer connected to the router ?
or is there any other computer able to go online ?
use that computer to find out the key.
Click Here for more info about how to find the key
Nov 12, 2009 | Zyxel P660HW-D1 Router
Zyxel P660HW-D1 Router Problem
my modem and router were working well, and then my router has stopped working
Aug 16, 2008 | Zyxel P660HW-D1 Router
Zyxel p660hw wireless problem
I forgot my modem wireless password...and I can not make a connection without cable...
Jul 12, 2008 | Zyxel P660HW-D1 Router
ZyXEL P660HW-61
while your computer is directly connected to the router, try to change the channel to 1,6 or 11. Try to enable wireless security and disable firewall on your computer. try to turn off other wireless device that may cause interference on your network
May 08, 2008 | Zyxel P660HW-D1 Router
Zyxel P660HW - Wireless Router adsl modem set up poblem
Check in network settings that the two computers have not the same IP address.
Feb 13, 2008 | Computers & Internet
Zyxel P660HW-D1 Router Logo
1,668 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
